Old 21st October 2007, 02:59 PM   #1
adrrad is offline adrrad  Canada
Default 8ohm or 4ohm?
I just want to let you know that I do not know very much about speakers and amplifiers. I got a Harman Kardon PM640Vxi, 4x45Watt + 1 pair of JVC SP-74BK loudspeakers rated 225Watt at 8ohm + 1 pair of speakers Infinity Reference 50 rated 150Watt at 6ohm. The HK is high voltage/high current integrated amp and has 4ohm and 8ohm capability as well. The idea is that I have a 4ohm/8ohm capable amp and 2 pairs of speakers: one is 8ohm and other 6ohm. My question is what output impedance to choose for amp? Is sound quality better for 4ohm or 8ohm? (The thing I noticed is that when amp is on 8 ohm the light for high voltage and the light for high current are both on. When the amp is on 4 ohm mode, the light for high voltage is off and the light for high current is on. Is sound quality better in 8ohm or 4ohm?).
Thank you in advance!
Adrian
Old 21st October 2007, 03:23 PM   #2
Did it Himself
richie00boy's Avatar
In a perfect world the 8 ohm load is easier on the amp. In the real world the 4 ohm speakers will have completely different response to the 8 ohm speakers so you can no longer simply say one impedance or the other is better.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 21st October 2007, 03:53 PM   #3
Thanks Richie. Is there really no difference? Considering the amp and speakers I got, in your opinion, which is better for me to use: 4 or 8 ohm?
Adrian
Old 21st October 2007, 04:08 PM   #4
Did it Himself
Just try both and see which you like the sound of, forget about the ohms of them
Old 21st October 2007, 04:24 PM   #5
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
The switch on the back of the amp that selects 4 or 8 ohm loads changes the rail voltages for the amp section. 4 ohm loads are harder on an amp so you have to use a lower power supply voltage to keep the output devices within their safe operating area.
Use the 4 ohm selection.
AJ
Old 21st October 2007, 04:29 PM   #6
Thanks for advices!
8ohm speakers 4ohm tap 5u4 Tubes / Valves 1 17th April 2009 11:22 PM
4ohm and 8ohm LR4 xo LukeDuke Multi-Way 1 17th April 2008 05:09 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
4ohm Car Speaker to 8ohm Use? jdgonko Car Audio 1 20th April 2006 02:40 AM
Page generated in 0.07187 seconds (75.91% PHP - 24.09% MySQL) with 10 queries
