Old 21st October 2007, 12:47 PM   #1
ashok's Avatar
Default Parallel LM3886 with 40 volt supplies
Has anyone being using a dual parallel LM3886 at +/- 40 volt supplies.
I tested the chip at +/- 40 volts ( unregulated) and it seemed to work well without shutting down. Any danger of breaking down in the long run ? I would guess that a mains surge might kill the chip ?
That might mean a supply surge up to +/-46 volts unloaded.
AM
Old 21st October 2007, 02:29 PM   #2
Default Too much
I have one, but the most I have seen is 40 - 41 volts. It will run hotter. I think that this is the way to go, will drive almost anything and should put out about 100 watts for headroom.
Without knowing your details, a 27 - 28 volt transformers will yield about all the chips can handle longterm. This may drop a little under load, but if the trannie is up to the task it should not be too bad.
Mine uses a single 600 va Anatek 28-0-28. They say is is a 660 va with 60 hz power. Seems about right. There is a discrete diode bridge for each chip and has 12,500 ufd on each rail. So 100,000 ufd total. There are eight rails, two for each chip. You might need a servo on each chip also.
Servos are nice, takes care of turn off clicks and pops.
George
Cheapest is bestest
Old 22nd October 2007, 07:10 PM   #3
Default Re: Parallel LM3886 with 40 volt supplies
You didn't mention what load you are using. If you go above a certain value, in voltage or load, the chip's internal protection will kick in and cause distortion.
Found a good stereo IC for 9 volt supplies johnr66 Chip Amps 0 16th March 2009 11:51 PM
Need Help with + _ 90-100 volt regulated power supplies wrich22 Power Supplies 4 21st March 2008 10:46 PM
DH-500 +- 90- 100 volt Regualted power supplies wrich22 Solid State 0 21st March 2008 10:13 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Power Supplies 12 Volt????? Co_Driver Solid State 3 6th May 2004 04:59 AM
Page generated in 0.07247 seconds (69.00% PHP - 31.00% MySQL) with 10 queries
