Old 21st October 2007, 11:45 AM   #1
Send a message via MSN to mischa72
Default Combination of chipamps
Hello all,
Before I used the name Rallyecoupe, but this registratoin did not give me the opportunity to post (strange), so I made a new account.
Now, to my question:
I am planning to build a chipamp for my Dayton Seventeen speakers. I want to Bi-Amp, so I need 2 Amps for each channel.
For the bass I want to use a dual-mono LM4780 kit, but for High (itīs a 2-way speaker) I am not quite sure which amp to use. Is there a difference in sound between the LM3875 and LM3886?
I want to order the amps at audiosector.com, but here I canīt order the LM3886 kit. Why I prefer this amp? Because I think this one sounds most like the LM4780 (which are 2 LM3886 amps in one housing). At audiosector.com I can only order the LM3875.
The other option is to use 1 LM4780 for both High-channels. At this point I donīt know if the channel separation is as good as with 2 separated amps. For the supply this all doesnīt matter, because I have 2 500VA toroids for the 2 supplies.
So, what would you do and, more important, why?
LM4780 + LM3886
LM4780 + LM3875
LM4780 + ― LM4780
LM4780 + LM4780 (maybe too much power on the tweeter)
The passive filter will be in the speakers, so I donīt use an active crossover.
Kind regards,
Mischa
Old 21st October 2007, 11:47 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
You must have missed your own post.
http://www.diyaudio.com/forums/showt...223#post651223
/Hugo
Old 21st October 2007, 01:21 PM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I prefer the sound of the LM3875 to that of the LM3886! However, I am currently using LM3875 for mid/tweeters, and LM3886 for woofers and it sounds fine. ie, I can't say that the woofers sound 'different' to the mid/tweeters!
So I think you will be fine with the combination of LM4780 + LM3875!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 21st October 2007, 07:45 PM   #4
/Hugo
Well, here I asked what I needed beside the kit, now I asked what kits would be best to use. At this moment I allready have the toroids, as you can see in my first post. I have to admit that I havenīt read my old post.
@Nuuk:
Whatīs the difference in sound? You say you prefer the sound of the LM3875 to that of the LM3886. Why?
Kind regards,
Mischa
Old 21st October 2007, 10:02 PM   #5
Nuuk's Avatar
It's very close and difficult to explain. But to me, the LM3875 is more musical.
Old 22nd October 2007, 01:21 PM   #6
So you say the 3875 is the better sounding one?
If I wouldn't miss the extra power of the 3886 (even if it's only 18W), the choice is easy, then I'll go for the 3875 and I can order everything in one place.
Does someone else have to add something to this?
Mischa
Old 22nd October 2007, 02:49 PM   #7
Nuuk's Avatar
Just how much is the '"high" part of your speaker going to need?
Old 22nd October 2007, 05:33 PM   #8
Nordic is offline Nordic  South Africa
Nordic's Avatar
I feel the same as Nuuk, its hard to put my finger on it, but I also found the LM3875 easier on the ear...
Also its much easier to work with, when you cut off the NC pins there is only 5 pins to work with, you can even fit that onto veroboard, with a little bending...
No mute pin to contend with etc...
Old 22nd October 2007, 09:55 PM   #9
I really have no idea. I hoperd you could tell me. On the other side, the power supply is heavy enough to use 2 LM4780 amps for each channel, but I wouldnīt know how large the heatsink should be if I did this. The difference in price is not that much, as I have seen.
Mischa
Old 22nd October 2007, 10:14 PM   #10
Nuuk's Avatar
Do you have any specs you can share with us on your speakers? That would help in deciding how much power you need, and therefore how big a PSU you need, what chips are best, and what size heat sink you may need.
Chipamps and more for sale sbrtoy Swap Meet 4 3rd July 2007 05:17 PM
CPU coolers for chipamps? mobyd Chip Amps 57 7th April 2006 01:45 PM
jimbo's chipamps jimbo1968 Chip Amps 8 12th June 2005 02:16 PM
Bad combination? Kongen Multi-Way 18 1st December 2004 11:52 PM
Chipamps and distortion Pan Chip Amps 0 19th November 2003 06:29 PM
Page generated in 0.10604 seconds (86.27% PHP - 13.73% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
