Hacking the Logitech Z5500
Old 13th December 2017, 10:30 AM   #621
swisssteve59 is offline swisssteve59  Switzerland
Hi treal512,
First of all, it would be helpful if you identify your system PID # and whether the Sub has loudspeaker clips or RCA's.
From my understanding, if you are sure your Sub is working 100%, you can perform a simple mod or simply buy an adaptor from ebay (see Post # 615) to operate on a home theatre amplifier, depending upon your PID #.
Good luck!
Old 19th December 2017, 10:13 AM   #622
I think this thread is now dead for problem solutions... 'shame... :-(
Old 3rd January 2018, 07:35 AM   #623
neosk is offline neosk
guess so :/ I've decided to dump the Logitech pod and am going for a full grown receiver. My aim is DENON AVR-X2400H - should perfectly cover everything including PC connection via HDMI/optical. The satellites I'll reuse from Logitech Z5500 and I'll try to bypass the subwoofer circuitry to be able to connect it directly.
Old 6th January 2018, 04:01 PM   #624
m4r3ck25 is offline m4r3ck25
Originally Posted by tomoso View Post
I made this cable for my subwoofer (PID R544) and not work. Any idea?
you have pre 636 and you are missing voltage regulator, read tread #547.
Old 6th January 2018, 04:25 PM   #625
For everyone who are looking something simple and working solution without much soldering here is interesting cheap item that works for dead z5500, it works very well with any version because its the same as simple d-sub, i just putted rca cable on it and works great with onkyo sr-504e that by the way has good crossover frequency adjustment from 40 to 200hz, keep mine for z5500 on 60hz and i lowered subwoofer level on onkyo to -5 so it isnt so loud.
Search ebay for D-SUB DB15 VGA Male Female 3Row 15Pin Plug To Terminal Breakout Board Connectors
2018-01-06 18_23_20-D-SUB DB15 VGA Male Female 3Row 15Pin Plug To Terminal Breakout Board Connec.png
Old 5th March 2018, 03:52 PM   #626
Nosyarg is offline Nosyarg
Default Need resistor values - Z-5500
Good morning,
Was wiring a Z-5500 when several resistors on the output board roasted. I need to know the replacement values for Resistors R125 - R129. Three of these are obviously toasted, so I thought I'd go ahead and replace all. Can't find a schematic anywhere and Logitech had no clue what I was referring to.
The resistors are so badly charred I can't see the bands to determine their values.
Is there anything else I should check while in there?
Old 11th March 2018, 02:54 PM   #627
tdisalvo is offline tdisalvo
This was exactly what I was looking for. How can I keep using my subs with a full on receiver. I was trying to figure out the easiest way, and it looks like it was done. Looking forward to getting my plug in to see how it works.
Old 18th April 2018, 04:35 AM   #628
playstation12000 is offline playstation12000  India
Default low sub woofer volume
I made a replacement cable solution for my z5500 control pod for pid R801. after connecting this to the subwoofer Im not getting the full subwoofer volume. it is somewhat limited to like 20% of the volume capacity. also the bass is not as good as what i used to recieve via control pod itself. i tried both the methods of soldering the voltage regulator to pin8 as well as without the regulator. but still woofer volume is low.. what could be wrong..?
Old 17th May 2018, 04:35 PM   #629
racperu is offline racperu
Hi, I have a PID 540, how would you work for this PID ?, I remain attentive to your answer. Thank you
Old 9th June 2018, 07:23 AM   #630
pokoo is offline pokoo
Hi members please i have logitech z5500 with pid 602 no pod to the subwoofer is there a way i can bypass and used it? Or can i buy the bypass cable on ebay and it will work ? please help
Hacking the Logitech Z5500Hide this!Advertise here!
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
a big z5500 problem sonofwind Chip Amps 0 12th March 2009 02:07 AM
Z5500 from Home to Truck! fireplug0510 Car Audio 1 3rd February 2008 09:00 PM
Logitech z5500 sattelites TB W3-871s. willhub Full Range 21 18th December 2006 07:50 PM
