Hacking the Logitech Z5500
Old 19th October 2017, 03:41 PM   #611
mateusz8591 is offline mateusz8591
Hi guys, i have a set of z5500 and my control pod died recently, i want to make a bypass cable that will make all the speakers working again. The pid is R844, can anyone help me with this ?
Old 20th October 2017, 08:52 AM   #612
adiash13 is offline adiash13
Hello, I have 2 logitech Z5500 systems and one 1 control pod, I need a schematic diagram for y svga cable because i want to connect all. THX and sorry for my bad english.
Old 20th October 2017, 12:36 PM   #613
PLS, PLS
Old 27th October 2017, 10:28 AM   #614
Default dual z5500 to one Pod
Hi guys, I have two logitech z5500 and one POD, the idea is i want to connect both systems to this sub control with a splitter y vga, i'm not sure how to make the connections to the wires and i'm afraid to burn the POD, can anyone help me with a connector diagram of the splitter?
Old 3rd November 2017, 03:44 AM   #615
huqiulian is offline huqiulian
Smile Logitech Z-5500 Subwoofer A/V Reciever Pre-out Adapter PID R001-R199 / R636+
Hello
We have just made a new stainless stell made an AV Reciver Pre-out adaptor for PID R001-R199 / R636+ on ebay , even gold RCA female out-put, any one would like to try this ?
For Logitech Z-5500 Subwoofer A/V Reciever Pre-out Adapter PID R001-R199 / R636+ | eBay
Also , there is Z5500 remote control we have just made for replacement , with fuse case holder , no setup need remote control , and fully tested for the function , hope it would be useful for guys here !
Remote Control For Logitech Z5500 Z-5500 With Fuse Holder English Version | eBay
If any other one need any other parts of the z5500 or something else , please kindly email me , we will do it for you
Old 5th November 2017, 07:56 PM   #616
tomoso is offline tomoso
Originally Posted by shb View Post
In order to use the subwoofer (PID R922) only with my AVR (Yamaha RX-V781) I made the cable like this. It works great.
One end is Female DE15 connector the other is Male RCA connector.
I altered a shielded VGA extension cable.
I made this cable for my subwoofer (PID R544) and not work. Any idea?
Old 29th November 2017, 05:16 AM   #617
Hello guys :
We offer 10 pieces logitech z5500 preout adaptor (for PID R001-R199 / R636+) , and 10 pieces logitech z5500 remote control for free on Amazon.com (FBA Primer shipping ) , please kindly email me if any one need , just 10 pieces for each remote and adaptor , limit qty !
Old 30th November 2017, 10:17 AM   #618
swisssteve59 is offline swisssteve59  Switzerland
Default Missing +8v ??
Hi everyone, I hope this post is still aliveÖ.
I have carefully read every post on this forum, but have not yet found the answer to get my system running again, so all trouble-shooting ideas and assistance is truly appreciated!
For clear identification, my system is as follows:-
PID R549, Spring Clips.
Symptoms:
After running at normal output for about an hour, the system suddenly died. No display or lights on the Pod. Fuse O.K., no obvious Ďburn-outí of components or dodgy soldered joints anywhere, but no usual Ďthumpí when switching on or off at the mains switch of rear of SW.
Initially I took the easy way out by buying the ebay Replacement Control Pod, but found this only gave me sound through the centre speaker only, no matter whether it was fully connected to my computersí 6ch sound card, or just on stereo through my iphone (trying each of the 3 Jacks for good measure). No good, just centre speaker onlyÖ.
So I took a look into the SW electronics and found the following:-
Preamp Board (taller version, with Sub D Input and speaker output soldered wire connections along the top):
WA119 (thick black): Ground Pin13
WA125 (thin black): -18.3v Pin15
WA124 (red/black): +17.92v Pin14
WA126 (thin red): +0.64v Pin 10
[The preamp board has 5 x ICís: 4 x R45801; 1 x HCT139]
Bridge Rectifiers (2 x KBPC1502): 35v from transformer
Main Board: Voltage Regulators: (U8): 78M18A & (U9): 79M18A
Problem:
Maybe Iím barking up the wrong tree, but my reading into this gives me the strong impression that all is not well without the +8v on Pin 10 (perhaps needed to fire up the Pod?), yet the voltage regulators are correctly giving me +/- 18v.
I have seen several posts throughout the history of this forum topic [#9 (Mause); #398 (Spacies); #499 & 545 (Casdit)], but havenít yet found the answer to the Ďmissing +8ví.
Can anyone offer any tips on what to check/measure? Iím fairly handy with my multimeter, which can also check diodes, but not skilled with ICís other than installation/soldering.
Thanks in advance for all,
Steve
Old 4th December 2017, 09:06 PM   #619
Nudge, anyone...?
Old 10th December 2017, 06:50 PM   #620
treal512 is offline treal512
Hey folks,
I have a pretty old Z-5500 set that I've had in storage for the last 5+ years or so due to a defunct control pod unit. When it originally went out I scoured the internet for information on how to remedy the situation, but was not able to find a good solution or maybe there just was not enough effort on my part.
Long story short- I currently have a decent 2.0 system for my PC and I just want to use the Z-5500 subwoofer in the mix. I will continue to look over this thread (huge), but does anyone have a fairly simple or straightforward solution to this? I am willing to crack open the sub, but I am not too great at soldering. I am very willing to give this a shot though as I believe there is nothing wrong with the subwoofer (fuse, etc.).
Thanks!
Hacking the Logitech Z5500Hide this!Advertise here!
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
a big z5500 problem sonofwind Chip Amps 0 12th March 2009 02:07 AM
Z5500 from Home to Truck! fireplug0510 Car Audio 1 3rd February 2008 09:00 PM
Logitech z5500 sattelites TB W3-871s. willhub Full Range 21 18th December 2006 07:50 PM
