Hacking the Logitech Z5500
Old 15th November 2012, 03:10 PM   #451
Archimedz is offline Archimedz
Is it possible easy check TDA7294 Amps, without desoldering ? Can anyone check resistance on TDA pin 10 and GND ?
Old 16th November 2012, 11:33 AM   #452
ExitusBlack is offline ExitusBlack
Hey Guys pls help me or give me the Link.
I have the first version auf the Z-5500 WITH RCA at the subwoofer.
I dont find a solution how to connect my db15 connector from the controlpanel to my 3 headphone jacks.
My first try faild with this tut.
Logitech Z-5500 Hacking Lautsprecher 3 Klinken Stecker 5.1 - Tutorials2k - YouTube
Old 28th December 2012, 08:11 PM   #453
Zertman is offline Zertman  United States
Does the Z-5500 control pod use its CS42526 chip for its DAC for all the channels? If so, which pins (26-37) correspond to what audio channels?
Old 28th December 2012, 09:45 PM   #454
leif2 is offline leif2
Default My sub keeps blowing fuses!
My z-550 sub recently started blowing fuses. Bought 6 blew them all. They were the same 4a/125 sloblow that it came with. I swapped pod units with my friends z5500. He confirmed my pod was still working on his Z-5500 and when I tried his pod I blew another fuse. I don't think I'm capable of repairs unless there's very explicit directions. Should I try to find some local repair shop? I'm in North bay SF bay area. Will satalite speakers sound good with a new subwoofer hooked up to a used receiver if I buy one on craigslist?
Old 6th January 2013, 06:57 AM   #455
cmeladio is offline cmeladio
Hi everyone! i need a diagram of the front left pre amp. My rc4580 was burned and destroy parts of the pcb, and i can't identify where to connect some smd resistors and caps. Please help!
Old 19th January 2013, 06:28 PM   #456
monar147 is offline monar147
guys are able to run some sort of freaked control panel? Voltage 18 - 18 and 8v normal. no backlight and standby. please help. sorry for my english
Old 28th January 2013, 12:19 AM   #457
PacoRG is offline PacoRG  Spain
Hi, I have a Z-5500 R473 and it has weird problem with center channel. I use the analog connections (3 cables), and last week the center speaker stopped working.
I checked the connections and everything seems fine. If I connect headphones to the pod, I can hear the center channel, so the sound is getting to the pod.
Also, If I enable the test mode with the remote, I can hear the noise on the center speaker, so there is some kind of connection between the pod (the amplifier) and the speaker.
In fact, if I use a digital connection, sound comes from the center speaker. I've been thinking about opening the pod and trying to check solders. I want to think it must be easy to fix. I would appreciate any help about where to look on the pod pcd.
Old 10th February 2013, 12:16 AM   #458
Xarpolis is offline Xarpolis  United States
Xarpolis's Avatar
Send a message via ICQ to Xarpolis Send a message via AIM to Xarpolis
Hello. I'm having problems as well, so let's add my post to the list.
I've had a Z-5500 speaker system on my computer for the last 8-9 years, and I've always loved it. A few weeks ago, it began acting up, and I'm wondering if anyone knows what might be the cause and/or what I could do to fix it. I love these speakers, and I'm not terribly thrilled with the newest version of Logitech's "top end" system, so I would really like to get this one working again.
While listening to some music, the front right speaker began to have static. It was random at first. A quick his for 1/2 a second every so often. I would power down the system (button on the control pod) and when I turned it back on, everything worked fine. After a day or two, this random static became much more frequent. While listening, I would have 5+ sounds in a minute. Shutting it down would stop it for a few more minutes, but then it would go right back to what it did before.
The next day, the static became longer. It would hiss for a good 2 seconds, then the entire system would stop making noise completely. The unit was still powered on, and there were no errors to be seen. The only way to get sound again was to click the switch on the subwoofer off then on, and this would clear whatever was causing the silence.
A friend of mine does audio support for the NFL. His company is responsible for making sure the coach to Quarter Back microphones always work. I asked him to take a look at the system, so he took the Amplifier (attached to the subwoofer) apart to look for any blown capacitors, chips or solder joints. He saw 1 possible "trouble" solder joint, which he repaired, and added a bit of solder to 2 other joints that, while functional, could give out at some point.
When I got back home, the system worked fine for about an hour, then Mute again. This time, there was no static prior to the silence. I guess that 1 faulty solder joint was to blame for that.
Anyway, now the system is completely unusable. It will only play for 30-40 seconds before going mute once more. I don't understand this, and would really like it to be fixed.
You can see a video of what's currently happening by clicking on the below link:
www.youtube.com/watch?v=xZS_mR4N_Nc
If anyone has an idea of what I could do to fix this problem, I'd love to hear it. I really really don't want to get rid of this system when it's perfect for everything I use it for.
Old 13th February 2013, 04:03 PM   #459
Bada54 is offline Bada54
Originally Posted by camouflageX View Post
Hey cliffdude,
Z-5450 15-pin Subwoofer to Control Pod connection
1 - N.C.
2 - Sub in (grey)
3 - N.C.
4 - Center in (green)
5 - Left Front in (yellow)
6 - Turn amps on (orange)
7 - Unmute left, right, subwoofer (blue)
8 - Unmute center (white)
9 - Right Front in (purple)
10 - +8V for Control Pod logic (thick red)
11 - Ground for Control Pod (thick green)
12 - Ground for Control Pod (thick blue)
13 - Overheat detect? (black)
14 - +12 V for Control Pod logic (thick brown)
15 - -12 V for Control Pod logic (thick black)
Shield - Blank wire
Pin 1 and 3 are not connected, because the Z-5450 has two wireless satellite speakers. For a wired speaker system these would be connected to red and brown.
A connection for the speakers to a 3,5 mm jack would look like this:
pin 5 <--- line out tip (audio for left speaker)
pin 6 <--- line out GND (unmute left, right, subwoofer)
pin 7 <--- line out GND (turns amp on)
pin 8 <--- line out GND (unmute center (optional))
pin 9 <--- line out ring (audio for right speaker)
pin 13 <--- line out GND (signal GND)
It would be nice to hear if you get yours working. Thanks!
1 -- thin brown wire = Rear right speaker
3 -- thin red wire = Rear left speaker
I spilt water on my control pod and save my Z5400 thanks to your post camouflageX
Old 14th February 2013, 09:08 PM   #460
adman1091 is offline adman1091  Canada
Default Almost Done....
I have a pid608 spring clip ver. I am using just the sub, no speakers.
I have +5v going to pin 7(white wire) that turns it on, i get a nasty tone outputted.
If i hook up my audio source (pins 2 and ground) i can hear it playing, but as soon as my input music stops the nasty tone is back.
Just wondering what to do to have no nasty tone when no audio is playing..
Help is appreciated.
PS is there any way of completely bypassing the preamp portion of the board and having the audio direct to the amp?
Thanks, Adam
Hacking the Logitech Z5500Hide this!Advertise here!
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
a big z5500 problem sonofwind Chip Amps 0 12th March 2009 02:07 AM
Z5500 from Home to Truck! fireplug0510 Car Audio 1 3rd February 2008 09:00 PM
Logitech z5500 sattelites TB W3-871s. willhub Full Range 21 18th December 2006 07:50 PM
