Hacking the Logitech Z5500
Old 1st September 2012, 09:48 PM   #441
bjorne77 is offline bjorne77
hello
i have one question i have 2 subwoffers and one pod/controler. i just whant to connect the subb no speakes to she second sub. can i use this thingy
VGA Y-kabel > Splitter | Kjell.com
and simply remove som of the pins that goes to the pod?
Old 12th September 2012, 01:24 AM   #442
YellowApple is offline YellowApple
Hello,
So while shopping at my town's local thrift store for weird electronics like I typically do, I encountered a strange-looking device and bought it on the cheap. Turns out it's the control pod to a Logitech Z680 system (and in hindsight I should have looked for some speakers to go with it).
So now I have a Z680 control pod with no speakers to go with it. How difficult would it be to rig up an adapter to have it control a set of amplified speakers (so basically the opposite of creating a headless Z680 setup)? All I'm seeing in the thread so far is for headless speaker setups, while I'm looking for a speakerless head setup.
I'd imagine that the control pod is outputting signals for each channel, plus receiving power and maybe sending some other data (that's what it looks like from this pinout description here). The problem is that the preceding pinout doesn't mention anything about power, but would the colors correlate to the same (or similar) purposes in the Z680 and Z5500?
If all else fails, it sounds like these control pods are in short supply, so I guess I could sell it off.
Old 17th September 2012, 05:20 AM   #443
wendle is offline wendle  Japan
Default Z-5300
I noticed there was some question on getting the Z-5300 working without the remote pod in this thread. I got it working (sort of), but had to bypass the pre-amp section to achieve it. Volume levels and crossover will need to be done at the source. My Asus motherboard does this properly.
Old 17th September 2012, 07:56 AM   #444
Oh .... here is the link to the thread:
http://www.diyaudio.com/forums/chip-...ut-remote.html
Old 20th October 2012, 10:50 AM   #445
SubaruB4 is offline SubaruB4  United States
I have a question I have the Z680 Logitech set and I want to use the sub with a Denon AVR 1612 what all do I need to do to interface it to the receiver?
Old 20th October 2012, 12:41 PM   #446
haes is offline haes
Hello
I have a problem with a Z5500.
The sub amp is generating umm.
Where is sub amp chips what needs to change.
Old 20th October 2012, 01:15 PM   #447
Hello
I have logitech Z5500
And sub amp is generating.
I think its tda chip but witch one?
Thanks to the help.
Old 25th October 2012, 02:47 PM   #448
psad80 is offline psad80
It is 100 Ohm
Thank You,
Prasad
Old 29th October 2012, 06:01 PM   #449
Archimedz is offline Archimedz
Hi, had problem with z5500, only center channel work, the problem is TDA amplifiers are Muted, no +5v on white wire. Can't find how to fix this.
Old 12th November 2012, 05:51 PM   #450
unistyle is offline unistyle
Hello everyone.
I have recently been having some issues with my z5500 system and figured I would see if anyone here could offer up some advice to what may be causing my issue. Sometimes the system will start working perfectly on any input, and then randomly it starts to make a very loud popping noise out of the speakers. The popping noise will continue regardless if I turn the volume down or change input. Finally I lose all audio completely. Sometimes I can get the audio to return if I cycle through the inputs, but many times there will be no audio or the display will say 'Detecting...' even on inputs that aren't plugged in. Sometimes it will just shut off on and return to standby mode while this is all going on.
The PID on my set is R510. I would be willing to perform electrical tests and soldering to fix this issue if needed. I just don't know what to start.
Thanks in advance for any help offered up.
Hacking the Logitech Z5500Hide this!Advertise here!
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
a big z5500 problem sonofwind Chip Amps 0 12th March 2009 02:07 AM
Z5500 from Home to Truck! fireplug0510 Car Audio 1 3rd February 2008 09:00 PM
Logitech z5500 sattelites TB W3-871s. willhub Full Range 21 18th December 2006 07:50 PM
