Hacking the Logitech Z5500
Old 22nd July 2012, 02:39 PM   #431
Peyton is offline Peyton
Originally Posted by Mortenhoe View Post
Hello guys. This thread has been truly inspirational! I'm very thankful that it's even possible to find this much information about hacking the Z5500.
I'm in NO WAY an audio geek. I have almost no knowledge what so ever in this field. I'm an electrician and I also like working with computers, inside and out.
At work someone told me they found a speaker in a house that had been auctioned away, and it was to be thrown out. I looked at it, and it was the subwoofer/amplifier from the Z5500 system, and it looked to good to be trashed.
I took it home, and thought it might be usable, but no. There was no control pod.
Then after some googleing i find you guys!
Now. What to do. My plan was making this into an active subwoofer, that would work together with my Sony 5.1 amp. It's got a preamp phono jack out, for subwoofer connection.
One of you had reverse engineered the pinouts, so it made the job quite easy.
I'm an electrician, so I have testing tools. I started measuring from pins on the connector on the back, to the circuit board inside, and found out where pin 6, 7, 8 and 13 ended up. Then I soldered 4 wires on. I mounted an RCA connector in the back of the subwoofer amp plate, and soldered the 4 wires to ground. The I found out that pin 2, Sub In, was the grey wire in the wire bundle, so I cut that and wired it to the center of the mounted RCA connector.
And it worked! My Sony amp can turn up and down the volume on the subwoofer individually.
Now I'm thinking about modding even more. I'm trying to find out, how I could alter the frequency range. The woofer is playing to much of the sound spectre.(Yes, that probably not how you say it)
Great work dude !
I had to copy your tweak on mine. For a while it works but now i got no sound after a quick but loosing "buzz". Did you success for frequency range ?
Old 3rd August 2012, 06:43 PM   #432
Sstevensn72 is offline Sstevensn72  United States
Yes that is what I currently have configured(the power to pin 8). AS far as the pots you should be able to find some that have dual wipers and configure it with one pot per set. I have found by putting the POTS on I was able to have much better volume control from the PC and not be blasted away at 5% volume.
Old 3rd August 2012, 06:51 PM   #433
I to am trying to figure out how to widen the frequency range on the subwoofer if it is possible.
Old 6th August 2012, 01:10 PM   #434
HorusIX is offline HorusIX
I was going to do the hack for the RCA version, after my POD died out of warranty (it's at least 4 years since it went out), mapped out the cables and made a schema opened the POD. But first i contacted Logitech (wow i am shocked) after two emails they decided to send me a new replacment pod for free even after the warranty went out!
I read alot about Logitech support being usless, but it's a long time since i recived such great and fast support from a company.
Just wanted to say that you guys who has a broken POD should try support first, if you hack it just to use it as a subwoofer it doesnt matter anyways
hack away!
Old 8th August 2012, 09:42 AM   #435
Qbaze is offline Qbaze
Thumbs up Logitech support
I was also going to hack my Z-5500 until I (luckily) read "HorusIX" post about contacting Logitech support. I didn't even consider that that was an option for me because of my system being over 2 years old and out of warrenty.
I contacted the english support yesterday and the said that they would be happy to send me a new pod even tho my z5500 was out of warrenty!
WOW! I did not expect that!
Thumbs up for Logitech support!!!
Old 9th August 2012, 09:46 PM   #436
Default Thats amazing considering they told me they had no more
Wonder what the deal is. I tried to do the same thing and they told me they had no more left. Which number did you call?
Old 11th August 2012, 06:36 AM   #437
Res506cue is offline Res506cue
Is there a pin out of the DB15 cable for Pre R636 systems? I have an R540 system with a dead control pod and was hoping to go headless to an A/V receiver.
Thanks,
Old 13th August 2012, 10:14 AM   #438
Question POD R108 to R514 system mod?
I recieved a new replacement pod from Logitech last week to my Z-5500 system, BUT they sent me a POD with a PID version that didnt work with my system.
My original POD i version R514. I guess I need a POD with PID# from R200 to R636??
( According to this cable it seems that way: Logitech Z-5500 (pre 636 PIDs) 3 jack Control Pod Bypass Cable w/ vol ctrl | eBay )
The replacement POD they sent me was PID# R108 and didnt work. Nothing happend when I pressed ON power, no light in the display and no light on the ON/OFF button.
After randomly pressing the buttons on the new POD, the display went on, but only the light, no symbols.
SO, My question to you all who have been successfully hacking your pods is:
Can I in some way get the R108 POD to work with my R514 Z-5500 system?
...or is the only solution to by a replacement cable as in the ebay link above?
/Q
Old 15th August 2012, 07:14 PM   #439
rjaii is offline rjaii  Tunisia
hi friends
i m new here,i m unlucky to have a podless z5500 pid r844, untill now i didnt hear the sound When I try and turn my Z5500 speakers on the control pod will not power up properly so I cannot get any sound - the red power light is illuminated so it is getting power but when I turn it on the power light goes blue for a split second and the screen shows the configuration but then the light goes red straight away and it turns off again,i see that many have made a bypass cable 5.1,many tuto ,witch one is right for my system(sorry for my english)
is it same of the other : to turn on amp 6+7+8+13
thanks
Old 30th August 2012, 07:12 PM   #440
scooby117 is offline scooby117
Originally Posted by rjaii View Post
hi friends
thanks
You probably have to replace D18.
Good luck
Hacking the Logitech Z5500Hide this!Advertise here!
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
a big z5500 problem sonofwind Chip Amps 0 12th March 2009 02:07 AM
Z5500 from Home to Truck! fireplug0510 Car Audio 1 3rd February 2008 09:00 PM
Logitech z5500 sattelites TB W3-871s. willhub Full Range 21 18th December 2006 07:50 PM
