| Chip Amps Amplifiers based on integrated circuits |
can anybody tell me how to get very good damping factor for LM3886 amp like arround 500-1000
thanks, Ken |
#2 |
diyAudio Moderator Emeritus
Brian |
#3 |
the (excess) loop gain reduces the open loop output impedance of a feedback amp
the loop gain falls as frequency increases there may not be enough loop gain to reach damping factors of 1000 with 4-8 Ohm loads at KHz with most chip amps |
#4 |
Place the chip amp inside the feedback loop of a high quality op-amp. This increases the overall loop gain, reducing distortion to vanishing levels and should improve DF as well. The technique requires putting a phase lead network and some attenuation between the two amps before applying global feedback and the miniumum stable gain is increased. It described how to do this some 15 years ago (or was it 20?) in an old issue of Radio-Electronics using an LM1875.
#5 |
Electrons are yellow and more is better!
Interesting question but is it necessary really? Isn't better than 50-100 high enough? Maybe it's a better idea to put the amp very close to the speaker instead.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
I think that use of a good quality high cap regulated supply would help a lot as many amplifiers can't really take advantage of a low output impedance because supply voltage drops under load thus ruining DF.
#7 | ||
Maybe if you measure DF at 100hz, you already get that 100's of DF with ordinary gainclone CCT? You can see OL decreasing steeply with frequency |
#8 |
What chip is that graph for, lum? 3886?
Poinz |
#9 |
Yes, it's from LM3886 datasheet.
#10 |
Considering that the DC resistance of the driver is in series with the back EMF of said driver, what does it matter if the output impedance of the amplifier is 1 ohm, 0.1 ohm, 0.001 ohm, etc.
It doesn't matter! As a practical matter, if the DF is below about 20 or so it affects the Qes of the driver, and thus the Qts. In general, box size is proportional to the square of Qts, so it begins to make a bit of a difference in this case.
Candidates for the Darwin Award should not read this author. |
| Damping factor in DIY amp | jaya000 | Solid State | 25 | 25th September 2008 11:27 AM |
| What is SI T-Amp DF (damping factor)? | skrstic | Class D | 1 | 23rd April 2008 09:49 PM |
| Damping factor | thylantyr | Solid State | 9 | 14th March 2003 06:37 AM |
| Damping factor..????? | emarald | Solid State | 15 | 30th January 2003 02:41 PM |
| Damping factor? High or low? | Joel | Tubes / Valves | 47 | 5th January 2003 08:38 PM |
| Page generated in 0.10082 seconds (80.31% PHP - 19.69% MySQL) with 11 queries |
