Old 16th October 2007, 12:52 PM   #1
Send a message via MSN to Denis.BR
Default My LM3886 chip amp
I would like to share with you my new home made chip amp. Its based in a LM3886 chip.
I made the housing all in steel plate, very cheap and easy to find. The painting is in epoxy powder:
Everything assembled inside the housing. I assembled the amp circuit and power supply in a acrylic plate, witch is easier to drill and fix with bolts and nuts.
Two chips for stereo, one chip for subwoofer:
Power supply: an old transformer from a vintage receiver and two 10000uF 63v EPCOS capacitor hidden under the board.
Rear view. Heatsink visible for style an cooling.
Click the image to open in full size.Click the image to open in full size.
Amp board:
Front view with stereo VU meter. The knob isn’t functional yet, but it is intended to control the subwoofer level. Instead using a regular LED for power on, I used a LED inside a optical relay box and connected to the front panel using a fiber optic. Very distinctive and bright.
I used the project shown in www.chipamp.com , and this power supply:http://www.chipamp.com/docs/lm3886-manual.pdf
It sounds very nice! I measured around 55w @ 8 ohms using 33V per rail
Old 16th October 2007, 04:11 PM   #2
gni is offline gni  United States
gni's Avatar
Looks like it will work: parts look like you used up the parts box!
Great way to recycle old parts into a new functioning unit.
I've never seen the chips that far from the rest of the circuit.. . but if
it works. . .good going.
Old 18th October 2007, 12:11 AM   #3
lgreen is offline lgreen  United States
lgreen's Avatar
Default nice
ha! nice! Gotta love using up those old parts; your transformer is missing a few nuts I see.
Hey what's the blue dealie with the red and green LEDs on it?
My DIY audio projects- PartTimeProjects.com.
Old 18th October 2007, 02:22 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Wow!Saw P2P but never seen this:multicore wires from PCB to chips!
Old 18th October 2007, 02:32 AM   #5
yep, it works indeed...
I chose this config because my PCB whas those "universal" (can't recall the proper name) and it was easyer to connect. The PCB had holes smaller than the LM's leads
Old 18th October 2007, 03:12 PM   #6
gni's Avatar
That means the feedback resistor is on the board and not soldered
directly to the chip. . .longer feedback loop? Or is it hidden by the
angle of the picture.
Old 18th October 2007, 03:21 PM   #7
yep, on the board.
But what's the difference? only a few inches away won't make any difference. After all, the energy is running at speed of light
Old 18th October 2007, 04:16 PM   #8
Is that transformer from an old pioneer amp?
Old 18th October 2007, 04:25 PM   #9
no, from a Kenwood receiver
Old 18th October 2007, 04:32 PM   #10
Cool. I have one just like that out of a pioneer, thats why I was wondering.
I see you have 3 chips there. What are you doing with the 3 in there?
LM3886 chip amp help danielnaveen Chip Amps 31 31st January 2011 02:33 PM
Chip amp lm3886 help needed!!! kanifee Chip Amps 7 23rd June 2008 09:01 PM
LM3886 or S5 K12M? ...chip or tube Kenkaru Chip Amps 3 14th January 2007 02:37 PM
A few questions about Building a LM3886 Chip amp??? Minion Chip Amps 21 13th October 2006 08:01 PM
My LM3886 Chip Amp bhk Chip Amps 9 22nd March 2006 12:33 AM
Page generated in 0.09602 seconds (81.02% PHP - 18.98% MySQL) with 10 queries
