Old 15th October 2007, 02:45 AM   #1
jarthel is offline jarthel  Australia
Default low value feedback resistors on LM3886
Is there any disadvantage if my feedback resistors are: 75ohm and 1.5Kohm (for a gain of 21).
Thank you
Old 15th October 2007, 05:32 AM   #2
Juergen Knoop's Avatar
temperature...power dissipation could reach 0,3W
which increases noise or maybe even cause thermal modulation.
Stick with the usual suspects 1k+22k! Those work fine.
Jürgen
Old 15th October 2007, 09:26 AM   #3
sangram is offline sangram  India
^^ I'd like to know more about this, if you can help me find some references.
I've used 22/1 and 4.7/220 (on different chips, though) and I'm still to figure out the effects and differences of these arrangements. I was going for lowest impedance to lower the output offset, and it did help. That was the only thing I could measure, really.
Would love to read more, though I'm beginning to get a hint of why this is true.
Thanks.
Old 15th October 2007, 09:32 AM   #4
22k/1k0 and 220k/4k7 ?
or
22k/1k0 and 220r/4r7?
or
22k/1k0 and 4k7/220r?
regards Andrew T.
Old 15th October 2007, 01:38 PM   #5
Sorry - 22K/1K and 4K7/220E.
Edit: Both the combinations were used on two separate amps at two separate points in time, the 'regular' one on all the 3886 ans 4780 amps I built, and the low resistance one on a (now exploded) LM4766.
Old 15th October 2007, 08:15 PM   #6
the usual values are just convenient. Small enough for noise, offset and parasitic effects.
Large enough for thermal effects and if you want to add some capacitors.
I think the LM chips are sweet tempered and one could choose the feedback resistors over a broad range.
regards
Old 17th October 2007, 01:42 AM   #7
Jürgen
what if I used 2W resistors? I suppose I shouldn't be concerned with heat?
Old 17th October 2007, 04:40 AM   #8
those have larger temperature coefficients, larger resistance tolerances and larger dc related noise.
I don't know, if all these theoretical disadvantages matter in a real world application.
But this is also true for the advantages.
What do you expect from lower value feedback resistors?
Jürgen
Old 17th October 2007, 08:53 AM   #9
a pair of double value paralleled resistors gets upto 1.2W. One to each side of the PCB helps keep them in the air stream.
One gets 50ppm/Cdegree using standard 600mW metal film.
There are sub 20ppm resistors available without going exotic.
regards Andrew T.
Old 17th October 2007, 09:03 AM   #10
yes, one can fight the disadvantages of lower value resistors.
But what justifies the effort?
Jürgen
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Feedback resistors with 'drop-in' replacementop-amps homemade Parts 8 14th February 2007 02:32 AM
Naim nap 140 feedback resistors fabus Solid State 5 4th December 2006 07:04 PM
draloric - any feedback on this resistors? jarthel Parts 2 23rd May 2006 11:02 PM
BPA LM3886 Resistors soundNERD Chip Amps 1 22nd November 2004 06:41 AM
Page generated in 0.09038 seconds (80.68% PHP - 19.32% MySQL) with 10 queries
