| Chip Amps Amplifiers based on integrated circuits |
I am looking to build a chipamp.com stereo kit, and have been mulling over what to do with regards to volume control. Has anyone integrated the aikido stepped kit into their gainclone? Is this a better alternative than using a simple pot? 36 position attenuator Second question....if it is a good option, would i want a 100k or a 20k kit?
#2 |
A simple pot will be a simpler solution, to implement and to use, but since you've seen this product and haven't gone running....
![]() The stepped attenuator will among other things minimise channel balance issues you could find some pots. One question you have to ask yourself is: what is my minimum required volume setting, and how big can I allow the steps to be? |
#3 | |||
It is my first and only stepped attenuator. I chose it for the low price, and because I need a balance control. Quote:
There is a lot less soldering to do with one or two pots, if you need to, you could use two mono pots, one each for each L/R channel. The Aikido kit gives me just enough L/R attenuation to make the balance right. I don't have many options for speaker placement. I don't know how the 20k and 100k kits would differ in this regard, but the center switch on the 20k would be better with more positions with smaller increases between each. I also connected a resistor in line with each input to the Aikido PCB to lower the minimum volume level. I would buy it again; the price was right, I learned something, and I'm using the Aikido attenuator at the moment. Really, I have no complaints, and I don't think anyone can beat the price. |
#4 |
Items such as this are available, too. This one has fewer steps but uses a single control knob. You could use a double pole switch to implement a level drop to effectively double the range if you needed it.
http://cgi.ebay.com/DACT-type-23-ste...QQcmdZViewItem Your input impedance (mostly the pot resistance) can usually be tailored to suit your needs with your variety of amp. Can your sources handle 20k? |
#5 |
the aikido is good. But the designer has forgotten the normal rule of Zout<=Zin/10 between the two stages. Buy as is and substitute the first stage resistors for ones with much lower resistance to get the best out of this attenuator. All the resistor selection data is on the website. eg. Source Rs=100r Zin balance control~2k Zout of balance control ~<=500r Zin attenuator~10k Zout attenuator~<=2k5 output cables must be very short. Zin amplifier ~>=20k These values prompt the question:- can your source drive 2k? Will your amplifier be happy with Rs varying between 0r and 2k5?
regards Andrew T. |
#6 |
I built the "lightspeed attenuator" and wired the optocouplers right to the chip amp. Amazing sound. See posts on this forum
Lightspeed Attenuator a new passive preamp |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Volume control | fragman56 | Tubes / Valves | 13 | 27th September 2003 04:42 PM |
| Page generated in 0.08576 seconds (79.42% PHP - 20.58% MySQL) with 10 queries |
