been browsing/searching through the threads for a simple power supply schematic that would power an OPA549 chip amp I'm planning on building (for guitar amp use)... and can't seem to find a basic schematic in this forum?
could anyone guide me to a schematic that I could follow...
I'm not to knowledgeable in electronics but could follow a schematic
thanks
thanks
thanks for the link... very helpful indeed
My amp would be based on the OPA549 which according to the data sheet could handle voltages between 4 and 30V, would using a different transformer, say an 18-0-18, help? I plan on having rail voltage of 20V what size transformer should I use?
To find out what the voltage will be after retification, use this formula
Vac * square root of 2 (1.4142)
Ex:
18Vac * 1.4142 = 25.4556Vdc
You want 20Vdc. Just turn the formula to:
20Vdc / 1.4142 = 14.1422
A transformer of 14Vac is the closest you will get, but 15Vac would be just as fine to in your case.
Ex:
Good practical informations can also found here :
Linear Power Supply Design by Rod Elliott
Power Supplies: Commentary for Consumers by Nelson Pass
Solid State Power Amplifier Supply by Dejan Veselinovic
artQuake
artQuake
here is another
Here is one of my schematics. O boy, thats big!
I posted this pic on my site because I kept forgetting which side of the diodes was which.
Hi Lgreen,
Could you describe the process for making the wav files? maybe a new thread with all the details for us newbies.
How about describing how we can generate different levels, eg.-20db -10db,-3db,-0.1db as well as -6db. is it possible to generate -0db without risking clipping of the signal?
and maybe a two tone sample for IMD tests.
Then how to get those signals out of the PC, both via the sound card with minimal degradation and onto a CD for audio testing.
- Chip Amps
- simple power supply schematics
