Old 9th October 2007, 08:59 AM   #1
Default Parallel with different chips!
I would like to ask whether I can parallel LM3886 with TDA2050 together, Thank you.
Old 9th October 2007, 11:36 PM   #2
I didn't look at the TDA datasheet but if both chips are the same type of output then as long as the gains are matched and use ballast resistors then it should work just like using two LM3886 chips.
-SL
Old 10th October 2007, 11:01 AM   #3
tangmonster's Avatar
I might be wrong but
building a car with two of the same type of engines connected to one gearbox seems like a possible solution to get more torque.
But building a car with two different sized engines connected to one gearbox seems to be just not a good idea. It will probably work, you may have a bit more power , but a single engined car will be so much lighter en simpler and easier to service...
just my feeling on this idea.
Old 10th October 2007, 11:22 AM   #4
Did it Himself
richie00boy's Avatar
It won't work reliably, the LM chip is more powerful than the TDA and their frequency responses will be different which could cause problems.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 10th October 2007, 09:52 PM   #5
OK, so I looked at the datasheets and it is not worth the trouble. The TDA2050 is not powerful enough. The TDA2050 can only be run as high as a +/-25 supply while the LM3886 can run up to +/-42V. Even if you parallel into 4 ohms so that each IC sees 8 ohms you still are limited to +/-25V maximum. This means no more power than the LM3886 by itself driving that same 4 ohms, and less because the LM3886 is rated at +/-28V for a 4 ohm load. Now if you're looking to drive <4 ohms then there might be some merit to it. Overall, get better matched ICs to do some parallel design.
-SL
Old 11th October 2007, 03:12 AM   #6
Thanks a lot guys.
Old 11th October 2007, 04:46 AM   #7
I_Forgot's Avatar
Hey, I like this idea. This is thinking "out of the box"!
One chip has a nice beefy bass with an unassuming upper register and the other contributes overtones of nutmeg and dark chocolate. You'll never find that combination in a single chip design!
I_F
Old 11th October 2007, 05:15 AM   #8
Send a message via AIM to DigitalJunkie
I_F
Could be good for a 2-way/bi-amped setup.
Old 11th October 2007, 05:34 PM   #9
Speedskater's Avatar
No, if the two chips don't have almost identical frequency and gain response they will fight each other every inch of the way. Each will try to force the other to whatever voltage that it thinks is correct at that instant.
Kevin
Old 11th October 2007, 10:27 PM   #10
I_Forgot's Avatar
That struggle, like an artist struggling to master his medium, is the source of the flavor of the mixed parallel chip amplifier!
I_F
gainclone chips in Parallel steven344 Chip Amps 2 21st November 2005 05:52 PM
Elegant way to feed parallel data-input DAC chips ? Bernhard Digital Source 27 18th April 2005 10:28 PM
Active Feedback on Parallel Chips Stocker Chip Amps 8 4th May 2004 10:40 PM
can I parallel 7812 Chips PaulHilgeman Parts 16 6th May 2003 10:05 PM
Balanced or parallel DAC chips A 8 Digital Source 32 18th March 2003 03:22 PM
Page generated in 0.10816 seconds (83.60% PHP - 16.40% MySQL) with 10 queries
