Old 12th October 2007, 03:41 PM   #11
Default parallel with different chips
It is possible to use two different chips in a bridge config, one as a voltage source and one as a current source. Chip A runs at a low volt supply but must be able to match chip B's current capabilities, chip B provides voltage gain and current output.
Yamaha used this in some of there descrete class A designs.
one side was a low volt high current class A bridged with a High volt class AB.
As for just parelleling two different IC's it would be possible but would require a great deal of design work. I might have to play with this idea a little bit, anybody got ideas on chips?? I've built many BPA designs useing LM's But havnt done much with TDA's or others..............
Old 14th October 2007, 03:48 PM   #12
I_Forgot's Avatar
Default Re: parallel with different chips
Screw all that. Just wire them in parallel. I say never be complete, I say stop being perfect, I say let's evolve, let the chips fall where they may.
I_F
Old 14th October 2007, 04:32 PM   #13
sam9 is offline sam9  United States
sam9's Avatar
Hey, I like this idea. This is thinking "out of the box"!
To jump back in the box (partly) why not precede them with an active crossover? One RCA jack in--> two pairs of binding posts out. It could all fit on one PCB. You might want to provide jumpers so you try swapping HF vs LF input to the amplifier chips see which does which range better.
Old 15th October 2007, 05:19 AM   #14
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default Parallel with different chips
Thought that before,but with LM3886 + TDA7293/4.
Old 15th October 2007, 07:33 PM   #15
I_Forgot's Avatar
That's biamping, not parallel with different chips.
I_F
Old 16th October 2007, 04:20 AM   #16
They will work or not is a different issue, but for sure, the sound will be smeared due to infighting.
Gajanan Phadte
Old 2nd September 2011, 12:24 AM   #17
Default TDA2050 can use as parallel
The TDA2050 is not powerful enough. & i want to more current by TDA2050 can i use in parallel...plz... any idia.........any one..
Old 2nd September 2011, 09:03 AM   #18
Jay,
if the chipamp cannot meet the duty you want to impose, then it's obvious (to me) that you should choose an amplifier type that can meet the duty you require.
regards Andrew T.
Old 2nd September 2011, 02:17 PM   #19
Originally Posted by tangmonster View Post
I might be wrong but
building a car with two of the same type of engines connected to one gearbox seems like a possible solution to get more torque.
But building a car with two different sized engines connected to one gearbox seems to be just not a good idea. It will probably work, you may have a bit more power , but a single engined car will be so much lighter en simpler and easier to service...
just my feeling on this idea.
easy to understand~
gainclone chips in Parallel steven344 Chip Amps 2 21st November 2005 04:52 PM
Elegant way to feed parallel data-input DAC chips ? Bernhard Digital Source 27 18th April 2005 09:28 PM
Active Feedback on Parallel Chips Stocker Chip Amps 8 4th May 2004 09:40 PM
can I parallel 7812 Chips PaulHilgeman Parts 16 6th May 2003 09:05 PM
Balanced or parallel DAC chips A 8 Digital Source 32 18th March 2003 02:22 PM
Page generated in 0.10238 seconds (77.32% PHP - 22.68% MySQL) with 10 queries
