| Chip Amps Amplifiers based on integrated circuits |
Hello,
I would like to try nos germanium transistors in simple three-transistor buffer designed by Andrew Rothwell and shown on Nuuk's website: http://myweb.tiscali.co.uk/nuukspot/...nclonepre.html The circuit is designed for NPN transistors. Transistors which I have are PNP. I do not know how to change the circuit to accomodate my transistors. Would swaping power supply rails be enough? Thanks for the help. |
#2 |
This amplifier is designed for silicon transistors and would not work with germanium even if you reversed the supplies, as the bias would be different. What type of germanium transistors are you hoping to use as I may have a suitable preamp circuit?
Tony. |
#3 |
Hello Tony,
Thanks for the response. I have 6 NOS TG52 transistors. This is a link to the datasheet. I have tried to attach it to this post, but the file is too big. http://www.datasheetcatalog.com/data...5/0/TG50.shtml People who built this circuit complemented its sound quality. I have recently heared few germanium amps and I liked the sound very much. Is it possible to change the circuit to accomodate TG52 transistors? I am a beginner in circuit design. I do not know how to do that. Tom |
#4 |
Hi Tom
It appears to me this circuit is just a follower biased by a 2 transistor CCS. Vbe for a silicon BJT is 0.6V. When enough current flows through Q1 and Q2 to establish 0.6V on R3, Q3 turns on more, turning off more Q2 so that a constant current flows in Q1 and Q2. A form of negative feedback. In this case, 0.6V/120Ohms is 5mA. For a germainium transistor, Vbe is 0.3V instead of 0.6V as for silicon. So if you wanted the circuit to bias with germainuim parts at 5mA, you would have to change R3 to 60 Ohms. Obvioulsly since you have PNP instead of NPN ploarity transistors, the rail polarity should be reversed as well. I don't see why it wouldn't work the same otherwise.
All the trouble I've ever been in started out as fun......
#5 |
Hi TB Ive just sent you an email.
Tony |
#6 |
Q2 & 3 are a Constant Current Sink (CCS), there is little difference in changing to a germanium based version, except that germanium is not as temperature stable and the CCS current may turn out to be not very constant. Q1 is the amplifier, operating in emitter follower (EF) mode. Sometimes known as common collector amplifier. The characteristic of EF is high input impedance and low output impedance. Gain is almost 1 (+0db). It makes a nice unity gain buffer.
regards Andrew T. |
#7 |
Writing is good exercize for the texticles! |
#8 |
Yep, but I would also go for a smaller R2, this will help against noise. Unless you are using a fet, BJT's like a more moderate source impeadance. Actually, this resistor should be matched to the output impeadance of the signal source.
#9 | |
Connect a low source impedance to the input. Now look at the impedance of that input line to ground. It is Rs//Zin. The effect of Zin is almost unmeasurable with respect to tolerance to interference. If a 20k pot preceeds the buffer then worst case Rs//Zin on the buffer input is 5k5//100k=5k2. As is usual for all high Rs sources the leads MUST be kept short and preferably screened. If that pot wiper feeds directly to the buffer input, interference susceptibility is not an issue.
regards Andrew T. |
#10 |
I was thinking more in general terms. IMO, it is better to have the lowest Zin possible for whatever the given application. For a mic input, obviously it wouldn't be that small. The application detail in this thread is vague.
| Does this FET buffer circuit look familiar? | homemade | Solid State | 8 | 27th April 2012 07:45 AM |
| Does this FET buffer circuit look familiar? | homemade | Parts | 1 | 9th January 2008 11:19 PM |
| Need tube buffer circuit for sub-woofer out | Gilbert | Tubes / Valves | 3 | 23rd July 2005 05:36 PM |
| Can anyone recommend a good buffer circuit | primalsea | Tubes / Valves | 9 | 23rd November 2004 09:58 PM |
| Need matched dual NPN transistors for I/V stage, quietest JFET for output buffer. | Brian Guralnick | Digital Source | 29 | 27th February 2003 03:55 PM |
| Page generated in 0.10231 seconds (79.07% PHP - 20.93% MySQL) with 11 queries |
