| Chip Amps Amplifiers based on integrated circuits |
Hello, this is my first post here. First of al, sorry for my bad English.
I’m now building my first serious amplifier, a bridged LM3886TF based on the schematic (BR100) of the Overture application note (1192) of National. Below are the schematics/boards that I draw. The power supply will be finished this week, and I just started drawling the amplifier board. Here are the drawling of my power supply ![]() I’m using a 500VA 22VAC Toroidal, and 50.000uF, witch will be enough. And the amplifier ![]() ![]() I have reed almost all topics in this sub forum according to the 3886, and they ware very useful. But my main question is, sins I don’t have any experience with the LM3886, is this schematic/board any good? Does anyone have any comments/improvements? Greets |
#2 |
Two things immediately jumped out at me:
- The feedback loop (the trace running from the inverting input to the output, via Rf) is too long. This should be as short as possible. I would put Rf horizontal, immediately below the LM3886. - A power trace is taking up space beyond the top of the LM3886. The board should end before here, otherwise you will run into trouble when you come to heat sinking it. Other than this, the board doesn't look too bad. Anton |
#3 |
Another couple of things:
- Cm is not in the signal path, so doesn't need to be a fancy film cap, a polar electrolytic will do just fine. Cm can also be shared between the two channels, and should be larger. Either 2x100uF, or one shared 220uF will do. - Use a star ground. All the ground traces should lead to a single ground point. On your board, the ground trace for your supply decoupling capacitors goes to the LM3886 ground pin, then to ground. They should all go directly to ground. Research the term star ground on this site. Alternatively, use a ground plane. Anton |
#4 |
Looking pretty good. But use plains instead of traces for the power, one on each side. As in this design i did a while ago. I use smd-components and bigger caps but otherwise its much the same...
#5 |
And the other side...
#6 |
most of your diodes in the PSU are back to front. Look at D5, 6, 7, 8, 9 and possibly D18. The bridge rectifiers look OK. T1 turns on RY2 after a delay. What is this doing? Pin3 turns off RY1. What is this doing? Where do out-2 & out-4 go to? I don't like mains voltage going through a metal encased resistor. Are you happy with that? +-30Vdc (it might be +-31Vdc) is right at the top end of powering 4r0 loads. Reactive speakers are an even worse load. If you bridge with this supply voltage the combination will be right at the top end of current and voltage for driving an 8ohm speaker. The bridged amplifier may not like it.
regards Andrew T. |
#7 |
good looking
#8 | |||||||||
You’re board looks very nice, have you got pictures of the finished amp? Quote:
The power_on (OUT-1) is to start the power supply. It turns RY2 (trough T1) and RY1 (trough IC3) imminently on. After a delay, RY1 will fall off. I already tested this cicuit, and it works just fine. Quote:
At 0.1 amps 22 * √2 - 0.6 = 30.5V At 8 amps (4 per amplifier) 22 * √2 – 1.4 = 29.7V ![]() Quote:
I started building my “capacitor rack”, it’s a little bit different than I draw, but it quite matches.
#9 | ||
The metal encased mains carrying/passing resistor is attached to what? Quote:
The sag in voltage at maximum output will be much higher than you've allowed for.
regards Andrew T. |
#10 |
| Bridged LM3886 psu. | kanifee | Chip Amps | 18 | 4th September 2008 01:57 PM |
| Bridged LM3886 (again ?) | Puffin | Chip Amps | 24 | 14th February 2008 08:10 AM |
| Bridged lm3886 suggestions Please | Scott_drake | Chip Amps | 55 | 16th August 2007 10:06 AM |
| Looking for a PCB for bridged LM3886 | zafira1981 | Chip Amps | 1 | 29th March 2006 03:39 AM |
| LM3886 Bridged Amp | soundNERD | Chip Amps | 1 | 20th January 2006 01:36 PM |
| Page generated in 0.13508 seconds (86.85% PHP - 13.15% MySQL) with 11 queries |
