| Chip Amps Amplifiers based on integrated circuits |
#11 |
#12 |
Banned
I would suggest building two boards one lm3886 on both . It will be easier for you to get a good layout it is good to keep + _ power traces together. keep fb loop very very short even solder fb resistor direct to the ic. keep inputs and outputs as far away from each other as possible. also keep input away from power traces. pin 7 should go to power ground also the ground side of the 0.1uf decoupling capacitors direct to power ground.
I am a newbie but i hope this imformation is of use to you . Good luck Ian |
#13 | |
All of your advice comes from reading good resources. Keep informing yourself and you'll soon be experienced. You have already passed Newbie status.
regards Andrew T. |
| Bridged LM3886 psu. | kanifee | Chip Amps | 18 | 4th September 2008 01:57 PM |
| Bridged LM3886 (again ?) | Puffin | Chip Amps | 24 | 14th February 2008 08:10 AM |
| Bridged lm3886 suggestions Please | Scott_drake | Chip Amps | 55 | 16th August 2007 10:06 AM |
| Looking for a PCB for bridged LM3886 | zafira1981 | Chip Amps | 1 | 29th March 2006 03:39 AM |
| LM3886 Bridged Amp | soundNERD | Chip Amps | 1 | 20th January 2006 01:36 PM |
| Page generated in 0.07180 seconds (73.30% PHP - 26.70% MySQL) with 11 queries |
