| Chip Amps Amplifiers based on integrated circuits |
Hi there!
I would like to use my last amplifier's transformer for my new amplifier, which would be based on an lm3886, but that transformer gives out +-50VDC and +-41VDC. Does any one of you have experinece with lm3886 and +-41VDc? I mean that the datasheet states +-42VDC the as the limit. Will it stand it? Thanks! With regards, Semir |
#3 |
If you are driving a normal speaker, as far as efficiency and impedance this is a bit much. It looks perfect for 16 ohm speakers, gets more power output.
For normal use, try a paralleled LM3886. With 40 volt rails, you might get close to 100 watts out of it. George
Cheapest is bestest |
#4 |
Sounds great to me
![]() ≈40±VDC is the right voltage to go with. Just stay below 80VDC if you can .
#5 |
You'll need big heatsinks...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 | |
Maybe, and maybe not. Depends on how much you drive it and what you call "BIG" heatsinks. |
#7 |
Put it this way, a 15cmx18cm heatsink with 3cm deep fins got warm with just the quiescent current draw on my 42V rail LM4780. And no, it wasn't oscillating.
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 07:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 06:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 12:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.08636 seconds (72.91% PHP - 27.09% MySQL) with 10 queries |
