| Chip Amps Amplifiers based on integrated circuits |
Could any one show me the schematic of OPA549 at unity gain esp. on the value R feedback? Also, any special concerns in running this consition? Thanks in advance! |
#2 |
Calculateing gain for the OPA549 is the same as for any opamp, but make sure that the OPA549 is unity gain stable as many power amp IC"s are not unity gain stable, check the datasheet....
Here is a calculator for calculateing gain: http://www-k.ext.ti.com/srvs/cgi-bin...obj(32618),new Make sure that you select the correct setting for inverting or noninverting configs.... Cheers |
#3 |
The OPAs are unity gain stable, and all the info you need is in the datasheet.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Thank you very much!
| Schematic for SoundTech Unity PA needed | jsevy | Instruments and Amps | 0 | 3rd December 2008 06:13 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| opa549 as unity gain | odysseybmx414 | Chip Amps | 11 | 16th October 2005 04:34 PM |
| NI unity gain opamp equivalent but with discretes needed | jondoe | Solid State | 5 | 10th December 2004 06:45 PM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
| Page generated in 0.07125 seconds (74.25% PHP - 25.75% MySQL) with 10 queries |
