Old 19th September 2007, 07:27 PM   #1
Default What resistor and potentiometer values for GC shunt volume control?
I have a modified dac-ah (8xTDA1543 with passive I/V) connected to a Peter Daniels LM3875 kit.
I believe the input impedance of the amp is about 18.5Kohm (?). The passive I/V resistor in the dac is 150R. I get about 1Vpp from the dac.
I have been using a PEC 1meg pot with 39Kohm resistor in fake law configuration. The sound is great, but the pot doesn't track evenly at the start of the rotation and the volume comes in very quickly so it is impossible to get a satisfactory channel match at low listening levels.
I picked this attenuator to work with my previous single TDA1543 dac which also had passive I/V but with a much higher output impedance. Now I have the 8 dacs running in parallel, I feel ready to change to a different attenuator configuration which gives better low level channel matching and lower input impedance.
What would be the best passive attenuator configuration to try? I am tempted to go with a 10Kohm series resistor and log pot in shunt position, but have no idea what value of pot would be best.
Or would another setup be preferable?
Any advice would be much appreciated :-)
Old 20th September 2007, 03:02 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
http://www.shine7.com/audio/gainclone.htm
Old 20th September 2007, 07:23 AM   #3
Excellent - thanks Leolabs :-)
Shunt or serie volume control maxpou Solid State 32 6th December 2008 05:07 AM
Shunted volume: pot & resistor values Sanaka Everything Else 20 13th February 2008 02:07 AM
Volume Control (potentiometer) SergeDufour Parts 1 6th December 2006 09:56 PM
Digital potentiometer as volume control Bricolo Solid State 15 29th January 2003 08:32 PM
Page generated in 0.05315 seconds (80.03% PHP - 19.97% MySQL) with 10 queries
