My LM3875 Poweramp My LM3875 Poweramp - diyAudio
My LM3875 Poweramp
My LM3875 Poweramp
Old 7th February 2003, 03:52 PM   #1
hatasa is offline hatasa
Send a message via ICQ to hatasa
Default My LM3875 Poweramp
Circuit base on the gaincone, but without the volume....
And the gain is lower than the suggestion circuit.
The Power supply cap using a pair of the 4700uf
working voltage at +/-35V
Using the 470uf for the by-bass
Resistance using with the RMG Japan...
Sound looks great, still running-in!
Old 7th February 2003, 04:04 PM   #2
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
Hi, Good work, they look great
I've always wondered, those amps have 2 channels, they are 30 watts on 8 ohm each i think, can you bridge them?
to make like 60 watts on 8 ohm? Because I have like 5 lm3875 and i wanted to do something out of them.
Time is the best teacher; unfortunately, it kills all its students
Old 7th February 2003, 04:10 PM   #3
Christer is offline Christer  Sweden
Those are probably the smallest monoblocks I have seen.
I wonder, however, do those boxes really provide sufficient
cooling or are you running the chips on rather low supply voltage?
Old 7th February 2003, 04:12 PM   #4
SlaitH is offline SlaitH  Sweden
looks very nice
cool thing with the small boxes. There isn't any coolers it doesn't get to hot??
/Patrik
Old 7th February 2003, 04:15 PM   #5
Ilianh's Avatar
Its true that these generate alot of heat, and I bet those monolocks get hot.. But I'm sure that unless excessive hours of listening at max volume its not dangerous for the LM's.
Old 7th February 2003, 04:35 PM   #6
halojoy is offline halojoy  Sweden
On Hiatus
Thumbs up hatasa - real good DIY Audio!
hatasa,
this amplifier DOES NOT fit in,
in the "UGLY amplifier" thread.
I like your work very much.
I do not think there is any worrying for too much HEAT.
When listening to music in a normal way
not much cooling is needed.
And I am sure LM3875 can take a lot.
Of course Capacitors can suffer from heat.
That is why I never put them TOO CLOSE to big heatsinks.
/halo - wants to buy hatasa amps ...
Old 7th February 2003, 04:51 PM   #7
Ilianh's Avatar
gosh... that was bad sorry, I got mixed up with some other amplifier with similar a name ... My bad..
lm3875 are 56w into 8 ohm.... with a 100w peak.
bah.....
(no, I'm not drunk)
I'm at school, working on lab, just tought I'd take a pause to see whats up on diyaudio..
Old 7th February 2003, 04:58 PM   #8
On Hiatus
Default Re: My LM3875 Poweramp
Originally posted by hatasa
Hi,Circuit base on the gaincone, but without the volume....
Using the 470uf for the by-bass Resistance using with the RMG Japan...
The only thing I would change is the Black Gates.
In my Opinion just a waste of money.
And ordinary Resistors are absolutely good enough
for any circuit.
/halo - have a little less money, than others
and manage just as good anyway
Old 7th February 2003, 05:03 PM   #9
saletel is offline saletel  United States
ok call me an idiot, but i've been wanting to do a gainclone amp for a while (not the reason i'm an idiot ) i only say that because i havent been able to find any schematics, so here i am asking. i'll probably be using lm3886t chips. so post a schematic for my simple mind. thanks
-Eric
Old 7th February 2003, 05:07 PM   #10
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
My LM3875 Poweramp Send a message via AIM to Peter Daniel
http://home.student.utwente.nl/f.s.b.../thor-amp.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
My LM3875 PowerampHide this!Advertise here!
YAP - Yet Another PowerAmp syn08 Solid State 315 4th October 2011 11:39 PM
LM3875 Poweramp- reflections on components... halojoy Parts 101 15th February 2003 12:44 AM
Copyright ©1999-2017 diyAudio
