| Chip Amps Amplifiers based on integrated circuits |
I'm new here, but it seems like a great forum. I'm going to build my first hi-fi amp now, and I have been looking at the Gainclone. Is this a good schematic?: http://www.shine7.com/audio/gainclonev1.htm But I'm not shure what transformer would be good. I'm going to build a stereo amp, and I have been looking at this: http://www1.schukat.com/schukat/schu...256D7900261D0A Will that be ok? Will there be any advantages in using a bigger transformer? Espen |
#2 |
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#3 |
Thanks!
Your amp looks great! I found that Hammond chassis that you used now, so I think I'll go for that one. Maybe the 1444-28, which is a bit smaller. |
#4 |
What about bridge rectifiers. How much current do they have to handle?
Are any of these ok?: http://www.banzaieffects.com/Bridge-...c-522-p-3.html |
#5 | |
Cheers, Gio.
#6 | |
the peak current and the average current through the rectifier is determined by the design of the capacitor input filter hung on the end. 8ohm speakers need +-20mF/channel for deep bass but, almost all chipampers believe this to be balderdash. I stick with this recommendation. Reduce the smoothing to +-4.7mF/rectifier and your 10A 280V version will survive without any added resistance to reduce peak current. If you go for +-10mF then, 10A may run too hot.
regards Andrew T. |
#7 |
Steve has the perfect transformers for the LM3886 for a great price.
You can build true dual mono for this price. http://www.apexjr.com/miscellaneous.html#Transformers XFM-D0012 is the part #. http://www.apexjr.com/images/AdireToroid.JPG
Troy Thinking positive doesn't make things better, it makes you a better person. |
#8 | |
For what it's worth I am using 20,000uF and two 8A 1000v SIL rectifiers per channel, one rectifier doing the positive side and the other one doing the negative side. With a pair of 8 ohm speakers at near full volume, playing music, the rectifiers on both channels are not even warm to touch, without any heatsinking. Same thing with a pair of "4 - 8 ohm" speakers I have. |
#9 |
I have already ordered the parts, and I ordered these rectifiers: http://www.banzaieffects.com/KBU1006-pr-24042.html Will they work ok? I bought the parts based on this schematic: http://diyaudioprojects.com/Chip/LM3.../LM3886_CA.htm The smoothing caps are here 10mF, but does that mean that I might burn the rectifiers? I'm going to use 4 Ohm speakers, at least for now. |
#10 |
As above... If my experience is anything to go by then I think you should be totally fine with that power supply schematic and those 10A rectifiers.
I use the 8A version of those in the same configuration, though I would have used 10A if I could find them at the time, and they don't even get warm. I do have a separate supply per channel though (i.e a total of 4 rectifiers). I think even with a single supply for both channels (2 rectifiers in total) would work fine. I wouldn't worry about it. Be sure to use a 100W-ish light bulb in series with the mains live before the transformer when testing the amplifier. It can help protect against some faults faults and, I believe, possibly prevent damage. The light bulb should light up brightly for a second or two while the supply capacitors initially charge and then go dim / not lit up at all. If it stays bright then something is wrong. Also, don't have your face too near the thing incase you have accidentally wired a capacitor reverse polarity etc and things explode! Might even be worth wearing safety goggles. I've got the supply reversed before on a tiny little opamp (NE5532) and you'd be surprised how violently they can explode. The chip's top flew up to the ceiling with a very, very loud bang! |
| 6 A transformer for Gainclone ?....help | AndrewGM | Chip Amps | 4 | 1st August 2009 02:12 PM |
| Looking for a transformer for a gainclone | mc_grumpy_d | Swap Meet | 5 | 26th November 2008 02:35 PM |
| Transformer for gainclone amp? | imperfectcircle | Chip Amps | 4 | 21st July 2006 05:13 PM |
| FS: Gainclone + transformer | tomchaoda | Swap Meet | 8 | 1st July 2005 01:35 PM |
| Gainclone Transformer | gchrist | Chip Amps | 2 | 18th December 2003 05:57 AM |
| Page generated in 0.11641 seconds (81.80% PHP - 18.20% MySQL) with 10 queries |
