Old 8th September 2007, 12:45 AM   #1
panson_hk's Avatar
Default My LM3886 Integrated Amp
Want to have an easy to build integrated amp for bed room, reading/working room ...; samples of LM3886 available, samples of various op-amp available. Okay, lets build a LM3886 integrated amp. Simple configuration: input source selector (all line level), buffer amp, vol control, LM3886+DC servo and output delay and DC protection.
Here we go the overall schematic.
Old 8th September 2007, 12:54 AM   #2
panson_hk's Avatar
And the bare PCB just received!
Old 9th September 2007, 12:16 PM   #3
panson_hk's Avatar
First round test passed. I simply assembled the amp section w/o DC servo (a large E cap temporary inserted in feedback) and fed it a 1 kHz signal. The output was an amplified 1 kHz signal.
However, I found layout errors: a missing resistor in DC servo and a short circuit. Luckily, easy to fix!
Old 9th September 2007, 12:25 PM   #4
panson_hk's Avatar
Next test with DC servo assembled. However, no FET input op-amp available, OP27G was used. The output DC offset is kept below 1 mV. The input 1 kHz sine/square signal was amplified nicely.
Old 9th September 2007, 03:55 PM   #5
banana is offline banana  Hong Kong
Hi Panson,
Nice. Looks like you used a ground plane finally
Old 10th September 2007, 12:30 AM   #6
panson_hk's Avatar
Hi banana,
Thanks! It looks more pro with ground plane. I mainly put ground plane to small signal section.
Old 10th September 2007, 05:59 AM   #7
Panson, try to exchange RPA_IN @ R1 and AGND @ R2.
The input impedance will be lower, but the sound - much better...
Regards, Alex
Old 10th September 2007, 06:12 AM   #8
panson_hk's Avatar
Hi Alex,
Do you mean to make LM3886 an inverting amp? I have been reading posts saying this is the best. Is there any reason behind? Or just experimental result?
Old 10th September 2007, 08:30 AM   #9
Originally posted by panson_hk
Hi Alex,
Yes, I meas exactly inverted amp. Experimentaly - 3886 sounds better in INV.
The second thing - driving the mute pin with the curent source, it is better, but not mandatory.
Regards, Alex
Old 10th September 2007, 01:22 PM   #10
panson_hk's Avatar
Thanks Alex!
Polarity of D8 and D2 of DC offset detection circuit is reversed.
New/Old Integrated LM3886 PCB Arius Chip Amps 12 10th October 2008 02:49 PM
3.1 integrated possible? Brit01 Tubes / Valves 4 5th July 2008 05:34 PM
Integrated Amp toman_9 Solid State 0 22nd January 2006 12:36 PM
New Fully Integrated LM3886 GC Arius Chip Amps 32 6th May 2005 07:44 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.10187 seconds (78.84% PHP - 21.16% MySQL) with 11 queries
