Old 6th September 2007, 10:34 PM   #1
Default Pre-Amp for Chip-Amp?
I was wanting to start on my first chip-amp project with a dual mono kit from Brian at chipamp.com. I mostly run a turntable, and I was wondering if I first need to run the TT to a pre-amp, then to the mono amps? Or will the monos work well without the pre-amp? If I need a preamp, does anyone have any suggestions for a pre-amp kit or schematic to use with this configuration?
Thanks,
Jason
Old 6th September 2007, 10:48 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
You need a phonoamp for a TT.. it not only amplifies the very weak output... and also corrects frequency response.
Look at the vsps as an easy phono amp...
Old 7th September 2007, 06:59 AM   #3
panson_hk's Avatar
Hi Jason
You need a pre-amp or more specifically a phono amp to amplify and equalize the output of a cartridge. If moving coil (MC) cartridge is employed, you need one more pre-amp! Typically, signal strength along the chain is as follows
Moving magnet (MM) cartridge : 3 mV -> Phono amp: 100 mV -> Pre-amp: 1V -> Power Amp -> Speaker
MC outpus is well under 1 mV. So, a pre-amp, either passive or active, needs to bring the level up to equivalent to that of MM output. Note, equailization (RIAA) is mostly done at phono amp.
Hope this helps.
Which Chip AMP you like most? dynabok Chip Amps 43 30th September 2008 08:55 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 04:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 01:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Hot chip! batkey Chip Amps 1 14th October 2004 11:54 AM
Page generated in 0.06686 seconds (70.84% PHP - 29.16% MySQL) with 10 queries
