Question about chip amp with different type of transformers???
Old 4th September 2007, 03:05 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Arrow Question about chip amp with different type of transformers???
Assume that the whole circuit is as same as the original Gaincard,just minus the input coupling cap,will there be any sound differences by using a normal square transformer vs a toroidal transformer???
Old 4th September 2007, 05:54 AM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
The input coupling cap shouldn't have any bearing on transformer choice or how the transformer affects the sound.
Assuming good quality transformers and good clean line voltage in both cases you shouldn't hear a difference.
Brian
Old 5th September 2007, 02:37 PM   #3
in general the EI and toroids available cheaply for the DIY market differ sigificantly in regulation.
The EI usually have a significantly higher regulation.
This may be audible.
regards Andrew T.
Old 5th September 2007, 08:30 PM   #4
KSTR is offline KSTR  Germany
KSTR's Avatar
But EI and especially UI have less bandwidth and less capacitive coupling than a toroid, which is often a benefit (less mains noise coupling)
As usual, a trade-off and the net result will depend on your actual system in total.
-Klaus
Question about chip amp with different type of transformers???Hide this!Advertise here!
Type of .1uF cap to bypass Vcc & GND on chip? riotubes Parts 2 20th October 2008 04:49 PM
which type of rubber cushion under transformers? vax9000 Tubes / Valves 18 3rd May 2008 10:44 AM
Type of battery for chip amp percy Chip Amps 25 13th June 2006 12:59 PM
Searching insulator type for LM4780 chip Peter Daniel Chip Amps 10 21st October 2004 01:34 AM
Chip (gainclone?) type headphone amp Vladco Headphone Systems 14 21st June 2003 05:31 AM
