Old 1st September 2007, 08:42 PM   #1
Default Clipping and amp power supply
I have an AR S500 subwoofer that is clipping badly at moderate to high levels, I have replaced the driver, and found a good working amp out of a 220 V unit and replaced all the boards except the power supply (of course) with no change, so my problem seems to be centered around the power supply.
This is a Sunfire 500W RMS plate amp with a large toroidal power supply transformer. Should I replace this or the two large capacitors that make up this power supply? I'm no technician.
Thank you!
Old 2nd September 2007, 04:30 AM   #2
djk is online now djk
djk's Avatar
Your chances of fixing that (even with the schematic), are slim, and none.
Those amps use a dual tracking down-converter (two switching power supplies that track the audio signal).
Candidates for the Darwin Award should not read this author.
Old 3rd September 2007, 12:08 AM   #3
I found the problem - a capacitor went bad.
Old 3rd September 2007, 03:53 AM   #4
djk's Avatar
An electrolytic in the raw supply, or one of the 6.8µF in the downconverter?
Pre-clipping as a method of power regulation bkoopman Class D 0 1st May 2008 06:18 AM
Clipping - power supply? digitaldisaster Subwoofers 1 1st September 2007 10:10 PM
Power Amplifier Clipping Indicator widi Solid State 2 1st March 2007 02:50 AM
Clipping vs Screwing Down Power Chips CarlosT Chip Amps 34 18th December 2006 09:15 PM
Sansui BA3000 clipping before peak power. Netlist Solid State 2 28th July 2006 07:41 PM
Page generated in 0.07926 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
