| Chip Amps Amplifiers based on integrated circuits |
Hi guys, hope someone can help me, i want to drive 1 or 2 LM3886 so im designing the PSU.
My transformer are Primary 220v/50Hz, and secundaries 28-0-28 (with CT). i cant figure how are the current that this PSU need to handle!, i dont know which diodes i need to use. Hope someone can help me, Regards. |
#2 |
Actually it depand on your amplifier. So for your transformer, Make it 3A will be good if you use it for both channel. or in other word maybe >168VA. For easy job, you can buy a bridge rectifier with rated 6A, 200v will work fine.
#3 |
Akita
i see some schematics that the LM3886 use +40 -40 for an single CHIP. If i drive just one channel with this values. how i calculate the current, i know that each chip is capable to give 68W into 4Ohms. and 50W into 8Ohms. i want to know how do the calculations to all diferent configurations. Thanks |
#4 |
#5 |
Ok, let's use simple calculation, P= VI, P=IxIxR,
When P=68,R=4, then; sqrt(68/4) = 4.1A P=50,R=8, then; sqrt(50/8) = 2.5A **The Actual Iq(A) is a bit bigger the the value above. |
#6 | |
Thanks, after use the xls file i found that use 4.73A. if i use 2 Mono Parts still need the same Current? or its the double? and is not possible to calculate it using an math formula? i want to know how its calculated to do my own calcs ![]() btw, that help me a lot, now i know that i need to use at least 8A diodes for an 8Ohms load and like 15A Diodes for an 4Ohms one :S |
#7 | |
ok, so i need to know the output power of the amp. and if i connect it to an 8ohms, 6ohms or 4ohms speakers, to know the current. Thanks too much!. |
#8 | |
Praudio |
#9 | |
Yeah i know will try to lower it a bit with something is the only Transformer that have at home now, i will use an 26-0-26 later i think. |
#10 |
is this a transformer/rectifier/smoothing cap PSU? Or is it a regulated PSU? The maximum current for two 3886 could be between 14Apk and 23Apk. Check the datasheet. Where is that going to come from?
regards Andrew T. |
| Problems while designing a guitar cabinet... | cb951303 | Instruments and Amps | 7 | 14th April 2008 06:34 PM |
| New problems with old Gainclone... | sek | Chip Amps | 13 | 3rd February 2008 11:48 PM |
| My Gainclone PCB - Problems? | shyfx | Chip Amps | 20 | 5th July 2005 11:56 AM |
| Gainclone with DC-offset problems | seve | Chip Amps | 11 | 28th May 2004 11:01 PM |
| help needed in designing gainclone | audioaction | Chip Amps | 14 | 31st August 2003 07:32 AM |
| Page generated in 0.09706 seconds (80.65% PHP - 19.35% MySQL) with 10 queries |
