what capacitor type is best used on Carlosfm's non-inverting chipamp?
Old 22nd August 2007, 06:58 AM   #1
jarthel is offline jarthel  Australia
Default what capacitor type is best used on Carlosfm's non-inverting chipamp?
This is not the latest but it would be close: http://www.diyaudio.com/forums/attac...amp=1112492461
I'm looking at C3, C5, C7 and C8.
Thank you very much.
Old 22nd August 2007, 11:54 AM   #2
metallised film caps could be used in all locations.
Polypropylene(PP) or Polyester(PES) would do.
You may find that low K ceramic will work, but you really must experiment if you try ceramic. Ceramic are generally smaller and cheaper. PP are generally bigger and dearer.
Some builders will suggest better quality caps for the decoupling around the chipamp. This applies to both the electrolytic and the bypasses. But again carefull experimentation and measurement should be carried out to ensure that ripple and oscillation on the supply rails is avoided.
regards Andrew T.
Old 22nd August 2007, 12:54 PM   #3
I have been searching and it seems polypro are inductive which is bad when use as a bypass caps (which I believe C3 and C4 are)?
Old 22nd August 2007, 03:02 PM   #4
Hi, polystyrene are usually rolled foil and these are definitely inductive.
Most makers of PP claim they make PP in a non-inductive form.
The obsolete stacked film polycarbonate were excellent in this respect, but nothing seems to be available to match the performance/cost ratio of these. The cheaper PP are getting close but tend to take up more space.
regards Andrew T.
Old 22nd August 2007, 04:11 PM   #5
rdf is offline rdf  Canada
rdf's Avatar
Wima's site has excellent technical information on this aspect. Cole's Notes edition IIRC: the inductance of a modern film cap is almost entirely determined by it's lead-to-lead dimension and is on the order of an equivalent length piece of wire. In other words at the limits of physics in a three-dimensional world.
Ears aren't microphones.
Old 23rd August 2007, 12:58 AM   #6
thank you. I was looking at the datasheet and cannot find such info.
Old 23rd August 2007, 01:03 AM   #7
Magura is offline Magura  Denmark
Magura's Avatar
Yes, you are right....or would be right, if you were to design a radar or the like.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 23rd August 2007, 01:06 AM   #8
rdf's Avatar
Not on a datasheet, ask and ye shall receive:
http://www.wima.com/EN/selfinductance.htm
Old 24th August 2007, 01:12 AM   #9
thank you
what capacitor type is best used on Carlosfm's non-inverting chipamp?Hide this!Advertise here!
What type coax to use on chipamp? ransom peek Chip Amps 9 23rd October 2006 02:12 AM
Improving the Non-Inverting chipamp carlosfm Chip Amps 247 18th April 2006 01:25 AM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 06:17 AM
Copyright ©1999-2017 diyAudio
