Banana's Pre - inelegant way to contrl vol - Page 3 - diyAudio
Old 31st August 2007, 03:48 AM   #21
banana is offline banana  Hong Kong
Page 1 of the discrete ADC schematic.
Total 10 quad comparators. In order to gain some precious PCB real estate, I use the more expensive push-pull comparator (instead of good old LM339). 40 pullup resistors are save.
LVL01 is the maximum attenuation. Below LVL01 is mute state, and opamp output relay will open.
LVL37 is 0dB attenuation, all 8 shunt relays are open.
LVL38~39 are the active gain state, audio signals are rounted to the variable gain opamp, without passing through the shunt relay attenuator. The comparator is connected as non-inverting for these 2 levels.
Old 31st August 2007, 05:07 AM   #22
Page 2, the XNOR chain.
This logic stage is to convert the cummulative output from comparator into decimal (01111 -> 01000).
Diode delay is added to some levels, to create anti-pop "make before break" for the relays. It's only required when relay state carries to the next digit (011 -> 100).
Old 31st August 2007, 05:34 AM   #23
Page 3, the diode mapping network.
36pcs of quad diode, correspond to 36 attenuation levels (LVL01~36). I assigned at most 4 shunt relay to be closed at a time, to save some power dissipation.
Old 31st August 2007, 05:37 AM   #24
The gain table that shows detail of shunt relay assignment.
V0~V7 are the 8 shunt volume control relays.
Old 31st August 2007, 02:25 PM   #25
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
nice very nice!
Old 1st November 2007, 06:01 AM   #26
Now another clumsy logic circuit, a remote control for my preamp.
Elementary FSK, 310Hz for volume down, 435Hz for volume up.
To avoid interference from other remote, IR carrier is 16.384KHz, much lower than normal 38K.
Receiver side is just bandpass pass filter, and a BJT H-bridge to drive the motorised volume pot.
Old 1st November 2007, 06:23 AM   #27
Schematic for the remote unit.
I didn't know why, but I couldn't get a 32.768KHz tune fork crystal to work... I lost patient and settled to use oscillator module IC, at 10 times the cost
Old 6th November 2007, 05:48 AM   #28
A photo of the IR receiver board, mounted behind the front panel.
Old 6th November 2007, 10:21 AM   #29
Send a message via Yahoo to si_jopie0382
Hi Banana,
Good job!
How about the sound? do you like it?
Jopie
Old 6th November 2007, 01:57 PM   #30
Thanks Jopie.
I was using passive preamp (24 steps grayhill switch) for years, and in fact I couldn't notice substantial difference after switching to the new preamp. The LME49710 is quite neutral and quiet.
The user control is better, there are finer steps in the low volume range, volume knob is much smoother than the stiff old grayhill, and now I have a remote.
Speaker connect: Speakon or banana Serge66 Tubes / Valves 12 14th January 2008 08:29 PM
banana or spade for 12-ga wire Alex Barnett Parts 4 29th December 2006 03:48 AM
banana plugs morpheus82 Parts 0 31st July 2006 03:15 PM
Where to find banana connections ChevS-10 Subwoofers 4 31st May 2005 05:11 PM
Source for paired banana jacks for amp amacks Parts 1 3rd January 2003 12:20 PM
Copyright 1999-2017 diyAudio
