| Chip Amps Amplifiers based on integrated circuits |
HI everyone;
I new on this and I am going crazy. i made a gainclone .It sound ok very nice no hum at all. but everytime i put it on the transformer get very hot eveen with no sound at all. I blew two of them in . any suggestion. i look at the boards and I do not see anything in short cut.The last time I take and amperimeter and it was going up until 4.5 amp. we use here 110v. any ideas? thanks ricardo
ram2768 |
#2 |
Ricardo,
I think your amp is oscillating. You need a scope to check. How big (VA) is your transformer? /Hugo |
#3 |
what do you mean
sscilating"And what is doing this? The transformer is 20+20 . The rare thing is that the sound is good and there is no Humm. do you think it can be a bad chip? ricardo
ram2768 |
#4 |
In simple terms, an oscillating amp is producing high frequencies that you cannot hear.
If it puts much of his energy in doing that, a lot of current is running all the time even when no music plays. A common cause is too long wires in the signal path or a bad board layout. Can you post a schematic and a picture of your amp? If it plays fine, the chip will be fine, too. /Hugo |
#5 |
I'm with Hugo, definitely sounds like oscillation. What is the current rating of your transformer?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
Well, if the chip doesn't get warm, it's probably not oscillating. Could just as well be an incorrect rectifier connection.
Do wizards use spell checkers? |
#7 |
Indeed, that is why a picture, showing the heatsink size could be handy. They could be massive.
![]() /Hugo |
#8 |
Whenever I wired up a rectifier incorrectly, the failure was usually instantaneous.
#9 |
diyAudio Moderator Emeritus
I had a similar instance once and believe it or not a power supply capacitor was bad and measured a low impedance. The amp worked and sounded ok but the rail voltage was low and the supply got very hot because the bad cap was a low impedance across the supply rail.
Brian |
#10 |
Yup, never happened to me, but that certainly sounds possible. Of course, it could also be a reversed electrolytic...
| NAD fuses, slow blow or fast blow? | AllCaster | Solid State | 3 | 25th October 2009 06:11 PM |
| resistor blow up ! | Ahmad_tbp | Solid State | 4 | 4th April 2006 06:56 AM |
| Blow up once, Blow up twice and Blow up somemore | S.C | Chip Amps | 14 | 6th March 2005 12:09 AM |
| Will This Blow Up? | Trout | Tubes / Valves | 8 | 6th February 2005 12:52 PM |
| Will it blow up? | dickerbeen | Everything Else | 1 | 17th April 2003 05:21 AM |
| Page generated in 0.08612 seconds (77.50% PHP - 22.50% MySQL) with 10 queries |
