| Chip Amps Amplifiers based on integrated circuits |
i have a tda2030 amp which runs good with fm radio. it has some noise when i turn the volume low but its acceptable. when i connect a casio pocket tv running on batteries there is no noise. but if i run the tv with 6v adaptor there is big noise. if i connect the tv audio signal to amplifier ground and and tv audio ground to amplifer input then there is much less noise. how can i reduce source noise?
#2 |
Though I'm not sure, but you may try-
1>try keeping away your adaptor from the amplifier 2> Looks the eliminator/adaptor has poor filtering. Try using a good adaptor. You may use a "LM7806" as a filtering IC Paswa from INdia |
| pocket headphone amp | tadiam | Headphone Systems | 1 | 14th December 2007 10:25 PM |
| Pocket pre-amp & headamp | digi01 | Chip Amps | 11 | 10th October 2004 12:49 AM |
| Another Chu Moy Pocket Headphone Amp | Devil_H@ck | Headphone Systems | 2 | 3rd January 2004 04:30 PM |
| Page generated in 0.05744 seconds (67.63% PHP - 32.37% MySQL) with 10 queries |
