| Chip Amps Amplifiers based on integrated circuits |
Well I just finished my first PCB design of a small 1W stereo amplifier. I really didnt have much of an idea of what I was doing, and it would be stupid to order boards that didnt work, so I was wondering if anyone could inform me of any errors, (Im sure there will be plenty) or tips to make my board better. The original schematic is on this page. My PCB picture will be attached. Please take a look. Thanks.
#2 |
diyAudio Moderator Emeritus
Hi Bubba. All of the grounds must be electrically connected. Your schematic shows three little "islands" of copper which are ground and those three need to be electrically connected.
Brian |
#3 |
Thanks, I was very unsure about that. Did you see any other problems?
#4 |
Actually, the input signal ground and the chip's ground need to be connected to all the other grounds too.
Other suggestions would include using thicker traces, using 45 degree bends instead of 90 degree bends, and tidying up the traces. It looks like you've made a double sided board but you can do this using a single sided board if it will cost less.
Brian |
#5 |
Does a double sided board mean that parts are mounted on both sides, or that there are two layers of copper? What's better about thicker traces, and 45 degree bends? Thanks.
#6 |
A double sided board is a board with copper on both sides. Traces run on both layers and parts may be on one or both sides of the board.
Thicker traces have lower resistance and can carry higher current. For your specific application thick traces are not needed but it would not hurt to make them thicker. 45 degree bends in traces have a better chance of being etched properly than 90 degree bends do. Board houses have improved in this area but it is still generally better to use bends that are 45 degrees or less where possible, especially if you plan on etching your own boards.
Brian |
| First PCB Design Revised. Still looking for errors. | BubbaGump | Chip Amps | 7 | 9th May 2008 07:22 AM |
| 15W kit schematic errors! | N9VOC | Chip Amps | 3 | 30th March 2008 10:47 PM |
| Head amp pcb. Please check for errors | wxn | Solid State | 8 | 11th June 2006 01:56 AM |
| need help in correcting errors urgently | weifeng | Parts | 5 | 13th February 2006 01:54 AM |
| denon dcd-485 cd errors hlp req plz | fender62 | Digital Source | 1 | 15th August 2005 02:48 AM |
| Page generated in 0.08938 seconds (71.08% PHP - 28.92% MySQL) with 11 queries |
