Old 11th August 2007, 12:34 PM   #1
Default fan-based cooling for chipamp
I would like to share this cooling solution with the forum. It's simple, cheap and works damn well.
History: as initially built, my gainclone recieved comments in this forum about the inadequcy of it's heatsinks. I agreed. After driving it hard for a few hours, it's Pentium 4 heatsinks became way too hot.
So, an internet search, Mouser order later, and a weekend later, voila...
http://home.comcast.net/~eric.ericks...clone/Fans.JPG
fans mounted to sinks
http://home.comcast.net/~eric.ericks...e/Fanctrlr.JPG
controller
http://home.comcast.net/~eric.ericks...thermistor.JPG
thermistor
I used this controller circuit....
http://www.rason.org/Projects/fancont/fancont.htm
...replacing the 2n2907 with a TIP42 (read: overkill). I used two 10k thermistors in parallel, one mounted to each heatsink, so I had to change R2 to 5K. Also, I changed R3 to a 5K and R4 to a 5K trimmer.
Old 12th August 2007, 10:39 AM   #2
Instead of using the Pentium 4 heatsinks why not re read the manufactures engineering data and size the heatsinks correctly?
This would eliminate running the chips at too high a temperature and eliminate the need for any special cooling circuits.
Old 13th August 2007, 01:59 AM   #3
Cut me a little slack, burnedfinger.
I had no prior experience with heatsinks as this is my first non-tube project. I'll know better next time.
Old 13th August 2007, 04:47 PM   #4
Check these out
Writing is good exercize for the texticles!
Old 13th August 2007, 04:58 PM   #5
troystg is offline troystg  United States
troystg's Avatar
Actually under "most" normal listening conditions those sinks would have been fine it the fins were vertically oriented and there were some vent holes beneath for convection flow. You may have even gotten away with chassis mounting the chips directly to the enclosure. It looks to be aluminum.
However, the fan controller circuit is WAY more interesting and I'm sure gave you a few hours of DIY fun...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 13th August 2007, 05:01 PM   #6
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
And it lets bubba use his current heat sinks! A job well done.
Brian
Old 13th August 2007, 07:04 PM   #7
Brian,
Are lexdyxic or what?????
It's UNITE, not UNTIE.
Sheeeesh man. Get wtih the porgram!
Old 14th August 2007, 01:21 AM   #8
bawang is offline bawang  Malaysia
Hi, oldfatbubba (nice choice for a name!)
The heatsinks are exactly the type that I am using for my PC based sound system in my office, again using LM3886s, except that I install them with the fins vertical and 5mm holes drilled on the bottom and top of the chassis. No overheating even when listening at LOUD levels, passive cooling. Now, if only I can get rid of the small residual hum.....
Old 15th August 2007, 04:30 PM   #9
Did you use a star ground? Are any wires carrying AC running near the inputs?
Old 16th August 2007, 01:20 AM   #10
Grounding is done as per the recommendations of DIYaudio members. A star ground for all ground wires (except input signal ground, which is connected to the PCB input signal ground) and from here connected to earth (casing, connected to socket earth) through a 10 ohm resistor. It's OK, I know that grounding is witchcraft in itself, I'll sort it out someday. For now, the hum is not offensive, you can only hear it if your ears are within 3 or 4 inches of the loudspeaker..... BTW, this is an ESP P19.
cooling fan controller for chipamp oldfatbubba Chip Amps 16 28th July 2007 05:41 PM
Chipamp-based Regulator? gootee Power Supplies 12 22nd January 2007 05:05 PM
PCB based invert 3886 chipamp assembly and comments digi01 Chip Amps 50 11th January 2005 02:57 AM
Page generated in 0.09720 seconds (79.64% PHP - 20.36% MySQL) with 10 queries
