Old 10th August 2007, 12:06 PM   #1
pejinm is offline pejinm  Serbia
pejinm's Avatar
Default blown gemini mixer - need help
Hi guys,
I found the blown resistor on the board of my gemini 3-chanel mixer (master not working).
I replace the resistor with the same value, and after 10 seconds the master output (resistor) has blown again. Here is the schematic with op amp and shown blown resistor on the negative supply rail.
What can be the couse of this problem?
Should I put resistor with 1/2W?
Thanks in advace for help!!!
Miodrag Pejin
"The quick brown fox jumps over the lazy dog."
Old 10th August 2007, 11:23 PM   #2
megajocke's Avatar
The opamp might be bad or the bypass capacitor shorted.
Old 11th August 2007, 01:51 PM   #3
Agreed.
Since R781 didn't blow, I would look for the bad part is in the circuit where 'Y' leads to.
Old 11th August 2007, 04:29 PM   #4
pejinm's Avatar
Thanks,
Problem solved...Both resistors replaced.Mixer working fine...
tone arm replacement on gemini XL 500 II jtwell2 Parts 0 2nd August 2008 12:58 AM
gemini GX-350 Powered Speaker JDogHerman Solid State 4 28th January 2008 10:20 PM
Tda7294 blown in powered mixer megajocke Solid State 5 15th January 2007 12:07 PM
Any Dynaudio Gemini owners ? H o m e r Multi-Way 3 25th September 2002 01:48 PM
Page generated in 0.26106 seconds (30.17% PHP - 69.83% MySQL) with 11 queries
