I made the usb based high-end  dac
Old 8th August 2007, 02:53 PM   #1
yangsmm is offline yangsmm  South Korea
Default I made the usb based high-end dac
I made the usb-based high-end dac.
It accept audio signal from PC through USB. PCM1798 is used to convert and AD827 is for I/V Converter and OPA627.
It is also used heaphone amp and has the digital out.
So powerful! What do you feel about this?
I'd like to listen to all opinions.^^
Old 8th August 2007, 03:07 PM   #2
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Your description omits the most important part: how do you convert the usb input to a format acceptable by the DAC?
No matter how good is the dac chip and analogue part you might have a real bottleneck here.
I made the usb based high-end  dacHide this!Advertise here!
Who made the most nicer and high end diy amp cases ? gaetan8888 Everything Else 3 5th March 2009 02:21 AM
WTB: 1 m well made high end interconnects rca rca pair thanks spwal Swap Meet 1 18th February 2007 02:31 PM
Any high efficiency woofers that are NOT made from paper??? sardonx Multi-Way 6 13th August 2005 07:24 PM
Did someone else than me noticed the sudden jump into high-end made by Adire Audio? simon5 Subwoofers 23 2nd May 2005 11:08 PM
Copyright ©1999-2017 diyAudio
