| Chip Amps Amplifiers based on integrated circuits |
I found this simple buffer schematic here on the forum and would like to know the proper way to add a small amount of gain.....
Can the standard method of gain for a non-inverting configuration work, or are there other things that need to be considered?
"If you don't like funerals don't kick sand in ninja's face." |
#2 |
Thats the way to do it.
If it's only a small amount of gain, nothing else has to be concidered.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
Thank you Jan.
Yes, only a gain of around 2 or 3. I am planning to add this buffer to an amp that has a passive volume control. The amp is Tripath TA2022 based and I would like to lower it's gain and add some to the buffer instead. Is there a huge difference between running an OPA2134 at +/-12v instead of +/-15v? I have a boat load of positive and negative 12v regulators, but no 15v.
#4 |
As you are using it to drive Line Level signals well below 5 Volts, there will be no difference using 12V or 15V. Various temperature of the OPAmp has much more influence.
#5 |
I forgot I made some mono "cmoy" boards with adjustable gain way back when and never used them for anything. If I remove the coupling caps, 100k resistors, and splice in the 47R resistors I'm all done.
(SMD on the bottom)
#6 | |
se |
#7 |
+-12Vdc will give a maximum output into a high impedance load of about 8Vac. +-15Vdc gives about 10Vac. The difference is a loss of headroom of less than 2db. Go for it, but use a unity gain buffer.
regards Andrew T. |
#8 | |
Adding gain to the buffer isn't a good solution for this?
#9 |
diyAudio Moderator Emeritus
Be careful because the opamps at the input stage of the Tripath amp are powered by a single 5V rail. We have no idea what the specs of the opamps internal to the chip are, so it would probably be a good idea to make sure the maximum possible input voltage is below 5V peak to peak (biased around 2.5V of course).
Brian |
#10 | |
It's worth trying sending a higher level signal to the amp. But now you need more headroom. +-18V supplies for 12Vac gets back 3.5db of headroom ref 6db of gain. You still lose out but much better than +-12V supplies.
regards Andrew T. |
| Phase change when adding gain stage? | bereanbill | Tubes / Valves | 1 | 15th May 2009 09:20 PM |
| Unity gain buffer in front of or behind TVC? | KT | Chip Amps | 9 | 26th March 2006 10:02 PM |
| Adding a buffer to my Zen V3 | Shoog | Pass Labs | 11 | 11th October 2005 08:15 PM |
| Unity Gain Tube Buffer | AKSA | Tubes / Valves | 41 | 2nd January 2004 11:11 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 07:50 AM |
| Page generated in 0.10281 seconds (80.54% PHP - 19.46% MySQL) with 10 queries |
