Old 3rd August 2007, 04:57 PM   #11
theAnonymous1's Avatar
Originally posted by BWRX
Be careful because the opamps at the input stage of the Tripath amp are powered by a single 5V rail. We have no idea what the specs of the opamps internal to the chip are, so it would probably be a good idea to make sure the maximum possible input voltage is below 5V peak to peak (biased around 2.5V of course).
So your saying the 2.5Vrms coming out of my DAC is probably as much as it can take anyway?
Originally posted by AndrewT
explained like this, then it begins to make sense.
It's worth trying sending a higher level signal to the amp. But now you need more headroom. +-18V supplies for 12Vac gets back 3.5db of headroom ref 6db of gain. You still lose out but much better than +-12V supplies.
Hey, I can pop some OPA551 in the sockets and and run them off the +/-30v regulated rails of the amp. I know, bad idea.... but talk about headroom.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 3rd August 2007, 05:03 PM   #12
Steve Eddy's Avatar
Originally posted by theAnonymous1
The Tripath amp is kind of noisy with the recommended gain. I've tried lowering the gain and it also lowered the noise, but then it doesn't play as loud (duh).
Ah, ok.
Adding gain to the buffer isn't a good solution for this?
I guess that depends on whether you can achieve the gain in the buffer with less noise than you'd have with the gain in the Tripath. If you can, then yeah, you'd be ahead of the game there.
se
Old 3rd August 2007, 05:17 PM   #13
Supply Voltage at Input Pins (pins 18, 19, 23, 24, 26, 28-32) -0.3V to (V5+0.3V).
Guess that's a no go on the gain. Thanks for pointing that out before I killed my chip.
Phase change when adding gain stage? bereanbill Tubes / Valves 1 15th May 2009 08:20 PM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 09:02 PM
Adding a buffer to my Zen V3 Shoog Pass Labs 11 11th October 2005 07:15 PM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 10:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Page generated in 0.06349 seconds (74.22% PHP - 25.78% MySQL) with 10 queries
