Old 2nd August 2007, 09:39 PM   #1
Arne is offline Arne  Netherlands
Default What amp to choose
Ok, here I am, slowly going nuts... I have a room in which I want to put a new amp. I have got a low budget and would like some really nice hifi quality sound in that room. I want to run my Arcam cd player and a set of TQWT broadbanders I am trying to get finished. They house high efficiency Isophone drivers, so I don't need a lot of wattage.
After considering cheap Chinese tube amps of Ebay or second hand amps from Rotel or NAD, I came to the conclusion that that might not be the way to go. A long time ago I read all the Gaincard/clone postings and got all excited about it. And then it died. Time has passed and I am back. So, what to do.
I am a beginner in building equipment. I do know how to solder, so that's alright. However, I have not kept up much. Is the Gainclone still the best option? And then, which one to build? Suggestions? I have been recommended the one on the Decibel Dungeon site, and that looks good. However, is there anywhere I can find step by step build guides as well?
Thanks a lot for any answers!
Yamaha HT amp, Quad 405-II, Arcam Alpha Plus, B&W DM220, B&W DM5 Isophone drivers and TQWT cabinets for a full range project, Harman/Kardon HT receiver, Infinity RS 4000, JBL MX1000, Garrard, etc. etc.
Old 2nd August 2007, 11:21 PM   #2
troystg is offline troystg  United States
troystg's Avatar
http://www.chipamp.com/
Full kits, great manual.
Upupa Epops has a very nice LM4780(?) amp.
Pavel Dudek's (Upupa Epops) LM4780 amp
http://c.webring.com/hub?ring=gaincloneamplifi
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 3rd August 2007, 09:24 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Yes.Gainclone is the best option.Easy to build/get help/advice,sounds good.
Old 3rd August 2007, 01:59 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Arne, have a little confidence!
I have had many complete novices contact me via Decibel Dungeon to say that they have built a GC and it has worked OK.
The trick is to do plenty of reading first. Go over each part of the circuit and try to visualise it and what it entails to put together.
Personally, I find hard-wiring a GC easier than putting a kit together but each to his (or her) own as they say.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 3rd August 2007, 11:26 PM   #5
Thanks so far for the suggestions.
@Nuuk; Thanks for your encouragement. I have been looking at your site and the GC's you have built. I looked for a way to get in touch with you, but the page on your site made me sit back and reconsider before I sent something. I will soon though. I have some questions left. If I look at your basic GC for instance, it has no volume control... However, I am wondering whether to build one or to build two monoblocks and add an input selector with a volume control so I can use 3 sources... But that is also making it much more complicated. I also like the TA-10 solution with jumpers, but that would probably compromise the sound quality over straight hard wiring. Which I feel is easier than a board as well.
The saga continues...
Old 4th August 2007, 12:45 AM   #6
Hi Arne.
I am one of Nuuks Newbies too. I have just finished a Uno preamp from DD for my first LM 3875 chipamp. It can done on stripboard and would give you volume control and multiple inputs, and it worked first time for me.
Its a bit more complicated but worth it in my opinion.
JB
Old 4th August 2007, 09:08 AM   #7
Nuuk's Avatar
It works! I didn't want that to sound unfriendly Arne but I was spending far too much time answering questions that were already addressed on the site.
To get you going, you only need a pot. I have a couple (10K and 100K) that I wired into small boxes that I an use to test nearly anything. I think this is covered in the FAQ section.
Re monoblocks, the amp section is monoblock. Start off with a shared PSU. You can add another later and see how that changes the sound.
My guru onece told me that a woman always does the washing up four times. Once in the kitchen sink and three times in her head!
Old 9th August 2007, 06:21 AM   #8
jduffy is offline jduffy  United States
jduffy's Avatar
Default Hehehehehe
I'm a Nuuk follower as well.
My everyday amplifier is a tube amp but during the warm weather I use a 3875 based on Nuuk's teachings. Just to keep the temp down in my place. It worked the first time I fired it up. Sounds quite brilliant as well. I run it with a tube preamp that doesn't generate anywhere near the amount of heat that my tube amp does.
Cheap, sounds great, what more can you ask for in the audio world? Oh, and I was totally new to the whole gainclone phenomenon so not a problem there. Good luck.
Old 9th August 2007, 08:01 AM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
Yep I also have a fully assembled Nuuk BIGC, in the livingroom under the couch as a gift for someone........ pretty decent sounding... I think that unit has a Rod Elliot P88 preamp in... with pan and volume control.
Favourite chipamp goes to Mauro Penasa My_Ref c. from Twisted Pair...
Old 10th August 2007, 10:51 AM   #10
Yep, it works. At least for me it does. I want to make a worthwile post if I make one. And be prepared, because I will. As soon as I have got it all lined up here...
You are right. I overlooked it completely. As I did with the shoppinglist. Now there is a great addition to a beginner.
Hmmm, interesting. Hadn't thought about that one yet.
Oh, and while cleaning out some mess, I found a Garrard. So tubes might be an option as well...
[Help] to choose AVR griv_brown Class D 0 7th September 2008 02:02 AM
What to choose?! rinx Multi-Way 12 29th September 2007 11:23 PM
Help me choose please fighi77 Tubes / Valves 12 10th June 2007 02:35 AM
To choose my irf 240 gegene Pass Labs 6 2nd March 2007 12:14 PM
Pls Help Choose a Fan JojoD818 Solid State 13 21st March 2003 04:58 PM
Page generated in 0.11986 seconds (83.67% PHP - 16.33% MySQL) with 10 queries
