Old 31st July 2007, 01:01 PM   #1
soundcheck's Avatar
Default Chip-amp challenging D-amp ??
Hi folks.
I am currently using a heavily modded Charlize module.
I read about certain Chips-Amps around here, which seem to be a real alternative -- on a first glance.
A bit of backgorund:
I've done some engineering on my entire chain in the past,
which ended up here:
DAC and AMP are integrated into one box!
I am controlling the volume with the PC (Linux), running a USB-DDDAC and connecting right to a heavily modded Charlize module firering 98db/SPL fullrange speakers.
The Charlize is powered by a 12V SLA (100Ah-Northstar) and delivering a gain of 14db ( my special setup! normal is 21db). This allows me to run most of my material at a prefered listening level in the range of 3db digital attentuation on the PC.
I tried a lot of other stuff, nothing came close to above.
The other issue I do cover with above ( "the flexible gain") balancing the difference between subwoofers and my fullrange by using different gains for each amp.
There is no further need to have a level adjustment between sub and fullrange.
Now back to the chip amp:
What would be a chip amp matching above setup, covering
a. flexible gain adjustment
b. SLA supply ( +/- 12V if possible)
c. soundquality
d. Not more than 3-5W power is needed
THX for your advise.
Cheers
Klaus
Old 4th August 2007, 11:11 AM   #2
Hi Klaus,
I have always been interested to try the TDA7384 after reading this thread. When I looked at the time of the thread I tracked it down somewhere but it was quite expensive (not very when you consider it is 4 channels). Seems to have been replaced now. Doesn't have flexible gain.
National have 12v 6W "boomer" amplifiers which have flexible gain - can't comment on sound quality.
Ross
DAC to Chip Amp davidallancole Chip Amps 8 18th May 2011 06:22 AM
help pls, challenging design - portable PA tbodin PA Systems 2 29th January 2008 08:49 AM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 01:29 PM
Hot chip! batkey Chip Amps 1 14th October 2004 12:54 PM
Page generated in 0.30423 seconds (18.52% PHP - 81.48% MySQL) with 10 queries
