| Chip Amps Amplifiers based on integrated circuits |
#31 |
The relatively "hard" surface of Kapton tape will not deform into the air gaps of the metal surface. The deformable isolators are designed to do exactly that and should be used dry.
Kapton should be gap filled.
regards Andrew T. |
#33 |
AndrewT,
What do you think of using the adhesive style Kapton tape? I have always used this out of convenience, but if there is a better method, I would love to know. Would it be better to use non adhesive Kapton with a gap filler on both sides? I would suspect the answer is yes, but it sounds like you have experience in this field, and I would like to use the best practical method! Regards, David |
#34 |
I have no experience with Kapton. The only thickness I found in the UK was far too thick (0.006" if I recall correctly). The adhesive is often 0.002" thick (and worse). I don't know how thermally conductive the adhesive is that is used. It would be nice if the suppliers/manufacturers would supply thermal data for both parts of the isolator and what the combined performance is with actual "To" sizes. But the few that specify don't tell us. What is the big secret? Why all the competing measurement units? Consistency and comparability would help. I have a feeling that 0.001" Kapton with a normal thermal compound on both sides will perform as well as the best out there. But that solution will not appeal to the assemblers. It is as unclean and slow as mica. The next best would be 0.001" Kapton tape + 0.001" to 0.0015" thermal adhesive (total thickness ~0.05mm). I suspect this may be outperformed by the best of the deformable but a lot cheaper.
regards Andrew T. |
#35 |
A general rule for when to use thermal grease is: Hard surfaces -- Yes, soft surfaces -- No. But many apparently hard surfaces (like many of the polyimide aka "kapton" foils) have a polyphase coating that gets soft and fills the gaps when reaching a certain temperature and gets hard again (but keeping its shape) when coming below that phase change temp (on the order of 50°C). With such polyphase coating, use of thermal grease is not recommended. Of course one needs it with mica and Al2O3 washers or with direct mounting as those are permanet hard surfaces. Compressible thermal pads like those made from silicone may only be used with components fixed to the sink at a single point (single bolt mounting). Components with multiple fixing points can easily be damaged when using compressible pads -- bendings stresses can cause the substrate to crack.
Some details on thermal accessories, catalog excerpts in a PDF: http://www.fischerelektronik.de/fisc...cher/E.1.E.pdf Similar stuff from another manufacturer: http://www.heatmanagement.com/kunze/...e/Products.pdf Regards, Klaus |
#37 |
Juergen, read a little more careful, please. I did NOT write something like "all kapton isolators have a polyphase coating and therefore don't use grease with these"...
| LM3886 Heatsink size? | henkel | Chip Amps | 28 | 11th April 2011 02:14 AM |
| LM3886 Heatsink | ormo | Chip Amps | 27 | 27th July 2009 04:15 AM |
| Required heatsink for 3 LM3886 in parallel? | CJ900RR | Chip Amps | 7 | 2nd January 2009 05:19 PM |
| LM3886 & Others Chip Amp Heatsink Clamp Solution | MartyM | Chip Amps | 7 | 18th October 2007 04:36 PM |
| LM3886 pcb approval wanted | wxn | Chip Amps | 21 | 7th April 2005 04:56 PM |
| Page generated in 0.09007 seconds (77.84% PHP - 22.16% MySQL) with 11 queries |
