| Chip Amps Amplifiers based on integrated circuits |
Hi
How much sounding BPA200 without DC-servo is worse? How to adjust offset voltage without servo?
http://mymegahobby.jimdo.com/ |
#2 |
The output offset is a factor times the input offset current times the difference between the two input source resistances. One can adjust the resistors attached to the non-inverted input pin. Trial and measure the error. Or add a trimming pot across the [standard resistor+20%]. The resistor may have to be increased rather than decreased. The slight disadvantage of the integrated circuit power amp is the range of temperature that the front end amplifier has to withstand during normal (and abnormal) operation. This causes more drift than in a similar non integrated (discrete) amplifier.
regards Andrew T. |
#3 | |
#4 |
I have one more question
An input buffer is required because of the low input impedance from paralleling of the inputs. If I am going to use the preliminary amplifier (Velleman-kit K8020) is necessary input buffer?
#5 |
Nobody can answer ?
#6 |
I would say yes, If the input resistors are less than 22K (I’m assuming you are using inverted amps).
22K/2=11k Specifications "Output load impedance: 10K or higher” |
#7 | |
#8 | |
#9 | |
If you use a chip like the DRV134, you can do away with the buffer. If you are going totally inverted (To trim away dc offset), you have to use a single end to differential chip or you could try something like http://sound.westhost.com/project51.htm Can you post your schematic? |
#10 | |
| Major Issues With Building The BPA200 Reference Servo Circuit! | MartyM | Chip Amps | 9 | 8th March 2008 11:50 PM |
| Max voltage for bpa200 | enter | Chip Amps | 29 | 19th February 2006 12:54 AM |
| Bpa200 | enter | Chip Amps | 2 | 3rd January 2006 09:16 PM |
| My BPA200 PCB | Dxvideo | Chip Amps | 14 | 11th December 2003 08:25 AM |
| Page generated in 0.09893 seconds (80.51% PHP - 19.49% MySQL) with 11 queries |
