Old 13th August 2007, 07:14 PM   #31
Professor's Avatar
More close to a theme, you do not advise to use these capacitors?
http://mymegahobby.jimdo.com/
Old 14th August 2007, 07:17 AM   #32
Originally posted by AndrewT
22uF sounds a bit big for a DC blocking cap.
What do you propose for the DC blocking back at the source, if any?
What is the Zin you propose at the power amp.
I am of the opinion that the DC blocking caps should set the Low frequency bandwidth of the amplifier. Setting this high pass filter too low then defeats that philosophy.
This post explained why I thought that 22mF was not appropriate.
regards Andrew T.
Old 14th August 2007, 01:19 PM   #33
Professor's Avatar
Then why in AN-1192 use 22uF ?
Old 14th August 2007, 01:24 PM   #34
Electrons are yellow and more is better!
peranders's Avatar
If non-inverting mode is that bad then why do almost all discrete power amps and discrete opamps use the non-inverting mode?
You must have all pros and cons of each mode, then you'll have to deside. Nothing is black and white you know.
/Per-Anders (my first name) or P-A as my friends call me
Old 14th August 2007, 02:17 PM   #35
What's the point in marking caps with 4 or 5 significant figures and then stating the tolerance is "J".
What have Jentsen (if that's the spelling) put in their soup?
The an1192 schematic has some odd component values.
See comments in other threads.
I am referring to the input cap. Those filters set, or at least should, the bandwidth of the amplifier. The 22uF in the NFB should be set to a lower frequency. That is why I said the 22uF PP soundwed a bit big and why I asked if there was a second DC blocking cap back at the source.
regards Andrew T.
Old 14th August 2007, 06:44 PM   #36
Professor's Avatar
I have understood. Strange, but I really had an idea to put 22uF on an input
Old 21st August 2007, 08:42 PM   #37
Professor's Avatar
Soft start and power supply for one monoblock
Old 21st August 2007, 08:44 PM   #38
Professor's Avatar
PSB
Old 21st August 2007, 08:45 PM   #39
Professor's Avatar
Soft start board
Old 21st August 2007, 08:49 PM   #40
Professor's Avatar
Major Issues With Building The BPA200 Reference Servo Circuit! MartyM Chip Amps 9 8th March 2008 10:50 PM
Max voltage for bpa200 enter Chip Amps 29 18th February 2006 11:54 PM
Bpa200 enter Chip Amps 2 3rd January 2006 08:16 PM
My BPA200 PCB Dxvideo Chip Amps 14 11th December 2003 07:25 AM
Page generated in 0.10566 seconds (81.16% PHP - 18.84% MySQL) with 11 queries
