Old 28th July 2007, 05:45 PM   #11
Juergen Knoop's Avatar
Originally posted by AndrewT
If you assume 24Vpk into a load from +-28Vdc supplies then the peak curent into 4r0 is 7A.
thats 100W peak power. Not enough?
Old 28th July 2007, 05:59 PM   #12
24Vpk into 4r0 is 50W.
A reactive speaker could have an effective impedance as low as 4*0.35=1.4ohms.
Now try sending that transient 24Vpk into 1.4ohms and the transient peak current could be as high as 17Apk. Except that National guarantees that spike protection has cut in long before then.
regards Andrew T.
Old 28th July 2007, 06:19 PM   #13
Ho,
I used your 7A. P=7*7/2*4 A*A*Ohm=98W
with 24Vpk, P would be 24*24/(2*4) V*V/Ohm=72W not 50!
Neverless, by increasing the requirements at will and worstcasing everything, one could hunt every design down.
regards
Old 28th July 2007, 06:51 PM   #14
obviously I can't even punch the right buttons on my calculator.
regards Andrew T.
Old 28th July 2007, 07:15 PM   #15
jackinnj's Avatar
'hittin that thistle wine again, eehhhh?
new to chip amps kendt Chip Amps 2 4th January 2007 02:48 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 12:50 PM
Chip Amps Huh??!!!! alecwek Chip Amps 10 26th July 2004 09:40 PM
Another hi-end amp using chip-amps dinamic1 Chip Amps 4 31st May 2004 09:13 AM
chip amps for ESL's? Few Chip Amps 3 30th April 2004 12:30 PM
Page generated in 0.08236 seconds (84.08% PHP - 15.92% MySQL) with 10 queries
