Old 23rd July 2007, 02:09 AM   #1
Arx is offline Arx  Canada
Default Grounding of opamps. Signal or Power?
If keeping seperate star grounds for signal and power, where would the opamps' (buffer and servo) power ground go to? I would assume signal ground, just due to the low currents involved. Is this correct?
-Nick
Old 23rd July 2007, 09:47 AM   #2
AndrewT is online now AndrewT  Scotland
no.
The decoupling across the opamp sends pulses into the power ground. Try to return these pulses separate from the clean audio ground.
regards Andrew T.
signal wiring / chassis grounding - Aikido cbutterworth Tubes / Valves 0 7th December 2006 05:18 PM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 11:07 PM
Grounding Idea for single opamps Franz G Chip Amps 10 28th December 2005 03:29 PM
Power grounding question falcott Chip Amps 0 21st September 2004 08:50 PM
Page generated in 0.06339 seconds (71.00% PHP - 29.00% MySQL) with 10 queries
