You can check out this link:
http://www.antiqueradio.org/dimbulb.htm
There is another website that describes it better, but I can't find it anymore.
You can also check out the second picture in this thread for the minimalist implementation.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=98157&highlight=
The mains bulb tester is dynamite!
Just get a socket from your home hardware store for the price of a couple of fuses!
So easy to build, saves you so much trouble.....
Reusing my own thread with another question.
The amp is now more or less finish..
On the left channel (speaker terminals on the back) the DC offset is 70 on the right channel it's 4...
Anny suggestions how to fix It.,, (most probable cause and so on)
Can the amp be used with such large gap in offset?
