| Chip Amps Amplifiers based on integrated circuits |
I have a small olson amp with screw down terminals on the back.
I have gotten some spade terminals to attach to the speaker wire and I am not sure which wire goes on which terminal. They are labeled... right right left left 8 ohm 0 8 ohm 0 Which is connection is positive and which is negative? Any info would be appreciated. I don't want to do any damage to the amp. I am clearly new to amps and have already blown one, so I'm just being cautious. thanks |
#2 |
sounds like the ones marked 8 ohm would be + and the others would be -
It doesn't really matter. you shouldn't hurt anything as long as you don't connect the speakers between left and right (and even that usually wouldn't do any damage) If you hook them both up the same way, it doesn't really matter which end is + and which is -, and will sound fine. If you get one backwards it won't hurt anything, It'll just sound really weird. Kinda spacey and with much less bass than normal. -Nick |
#3 |
thanks very much.
i just wanted to be sure before i tried it. |
| Screw Terminal Caps for Sale | Killjoy99 | Swap Meet | 15 | 27th January 2009 06:08 PM |
| Screw Terminal help | Zahrec | Parts | 4 | 27th September 2008 05:19 PM |
| FS: New Mallory 15,000µf 100V Screw-Terminal Capacitors | EchoWars | Swap Meet | 15 | 23rd March 2008 07:43 AM |
| Mounting screw terminal capacitors to chassis | ssmith | Pass Labs | 1 | 6th October 2007 05:25 PM |
| Using terminal blocks as Speaker connectors? | Beggar | Parts | 4 | 27th July 2003 09:08 PM |
| Page generated in 0.07703 seconds (66.88% PHP - 33.12% MySQL) with 10 queries |
