| Chip Amps Amplifiers based on integrated circuits |
#11 |
Dear Andrew,
Sorry for late answering. But I am working on my new Class A project as you know. Anyway, Yes as you see CS1&2 is on bottom layer. I saw a lot of benefits to keep there close to the power pins, especially on HF interferences. For rail to rail caps; I've tried that with many different values of caps; 47uF + 100nF, 100uF + 470nF however I couldnt hear any difference on sound. Some diyers recomment that way very strongly but I cannot. For example in my LM4702 project I applied the original factory design for MOSFETs. And in this configuration there was a 100nF poly between rails. I tried the circuit first with that cap and I feel some bass weakness, after then tried without it and the same bass weakness was still exist. But when I put extra 1000µFs on each rail to gnd then bass response was improved A BIT but not much. And for the unused pins. Generally I trim that pins, so they never be soldered to the PCB anyway. ... Dear Glenn, I havent noticed that pin 7 is sinking 1mA current. Thats interesting. Is this the main difference between LM3875 and 3886? Because as you know, there is no GND pin on LM3875. Thx for the reminding.
Best regards, Ozgur |
#12 | |
It's main (only) advantage is the way it allows the chip to handle fast transients.
regards Andrew T. |
#13 |
connect to sg,or through a 10uH inductors to sg.
Zang |
#14 | |
Makes me think about the option to generate a seperate GND potential for that pin that is stable with reference to the neg supply. When there are internal current sources etc. attached to the GND pin that also might explain the weak -PSRR curves of the chip, in case this isn't mainly due to the miller cap -- creating the amps dominant pole -- which semms to reference to the V- supply. And maybe the Miller cap is actually hooked to the GND pin. A lot of vague guesswork... Regards, Klaus |
#15 | |
Regards, Klaus |
| LM3886 Current needs. | svbear | Chip Amps | 13 | 29th April 2007 08:11 PM |
| LM3886 Max Current | thomasfw | Chip Amps | 1 | 24th May 2005 07:03 AM |
| LM3886 Quiescent current | NITRO | Chip Amps | 4 | 20th April 2005 10:06 PM |
| lm3886 current at pin 8 | jaudio | Chip Amps | 3 | 29th December 2004 09:59 AM |
| LM3886 and it's quiescent current | Toster | Chip Amps | 5 | 5th May 2003 10:23 PM |
| Page generated in 0.09072 seconds (78.27% PHP - 21.73% MySQL) with 10 queries |
