Old 17th July 2007, 02:58 AM   #1
Arx is offline Arx  Canada
Default softstart on bpa?
what would be the effect of putting a softstart on each chip on a bpa circuit (using the mute pin)? It does input muting, correct? If so, I guess the outputs would fight until all the amps came up.
would sharing a capacitor make them close enough, or is it best just to leave them out?
-Nick
Old 17th July 2007, 03:13 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Sharing the same muting circuit would be nice.
Old 17th July 2007, 03:04 PM   #3
soft start is the term usually applied to reducing the start-up current in a mains transformer.
Do you mean applying a delay to the mute/unmute pin?
So that the amp and surrounding circuits have time to stabilise before sending a signal to the speakers?
I would couple a resistor to each mute pin and then connect the other end of all the resistors together. Applying voltage or ground to the resistor junction will mute/unmute all the chipamps simultaneously.
regards Andrew T.
Old 17th July 2007, 04:40 PM   #4
Well, it's a little more than just a delay, since as I understand it, it will unmute gradually as a capacitor voltage climbs and the current starts to flow out of the mute pin.
I'll probably just tie them all to V- with a resistor, since that seems like the safest option.
-Nick
Looking for a softstart kit... rtate Solid State 7 28th February 2008 04:09 AM
When to use softstart lordvader Power Supplies 27 29th November 2007 11:41 AM
Softstart for Zv9? sts9fan Pass Labs 7 8th November 2006 02:33 PM
Yet another softstart PCB harryeng Pass Labs 5 24th January 2006 09:25 PM
Page generated in 0.08241 seconds (73.50% PHP - 26.50% MySQL) with 10 queries
