| Chip Amps Amplifiers based on integrated circuits |
#21 |
What is LTP?
How about if i apply the same sort of connection to another amp, what will it affects? As in the 22r crossing from the left chaneel to ground and the right channel, another 22r to the ground. |
#22 |
LTP=long tail pair.
it is not 22r from output to ground. It is an attenuator and the resistance from output to ground is 1000+22r=1022r or 1k0//1k0+22r=522r or 1k0//1k0//1k0+22r=355r. Take your pick.
regards Andrew T. |
#23 |
I think i get it finally(OMG)
1000+22r=1022r or 1k0//1k0+22r=522r or 1k0//1k0//1k0+22r=355r its for a single channel right, no crossing over the left or right channel, basically as a load to reduce gain/ amplitude. |
#24 |
out of curiosity i am just wondering how is a combination like this different from just a single resistor itself at say 355r or 522r
#25 |
The single resistor dissipates the total power.
You may end up having to use a wirewound. I chose 1k0 because Pd=V*V/R=20*20/1000=400mW when the amp is delivering 50W into 8ohms. Short term excursions to around 400mW will not cause any long term damage to a 600mW metal film resistor. Even peak voltages of 24Vac when only driving the headphone attenuator will bring Pd to about 576mW. This may cause long term degradation of the resistor. If you think that you may drive your chipamp that hard into headphones then select 1k5 rather than 1k0 as your parallel dropper resistors. The only difference that choosing 1k5 will be that more are required in parallel to raise the volume at the headphones if they are too quiet.
regards Andrew T. |
#26 |
I am finally going to get to working on the lm3886, all the parts are ready and I am going to have a headphone output, can i confrim that using the configuration will not damaed my headphones, in which they range from 16ohms - 600 ohms.
| My LM3886 Stereo Amp. w 12-0-12VAC Transformer | Andreq | Chip Amps | 27 | 1st May 2011 05:32 PM |
| transformer for LM3886 dual mono kit | gonzalez | Chip Amps | 16 | 11th October 2008 09:55 AM |
| LM3886 w/transformer $100 plus shipping | nodiak | Swap Meet | 0 | 22nd July 2006 11:53 PM |
| LM3886 - What Transformer ? | HarryK | Chip Amps | 19 | 12th March 2005 07:51 AM |
| Smaller transformer for lm3886 amp? | ted | Solid State | 6 | 14th April 2003 02:41 PM |
| Page generated in 0.08162 seconds (73.36% PHP - 26.64% MySQL) with 11 queries |
